F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Electrical Systems
Thread Tools Display Modes
Old 06-03-2009, 02:33 PM
Vehicle: 1998 Ford F-150
Send a message via AIM to Raptor05121 Send a message via MSN to Raptor05121 Send a message via Yahoo to Raptor05121
Truck wont start/clicking-bad connection?
Well yesterday I was installing my efan controller. I simply wired the red positive into the starter solenoid and when I went home she was clicking. So I simply jump-started into second and thought it was a dead battery. Well this morning she won't start. I took off the battery terminals and cleaned the posts and terminals with some sandpaper, and even poured some Coke into the showing wires that are crimped. I know the battery has juice, but she just wont start, just an annoying clicking sound.
I'm having trouble if it is the starter solenoid or the battery connections?
4.2L V6 - M5OD | 16" Dual Efans | 2" Drop Shackles | K&N Series-77 | Port & Polish TB
Old 06-05-2009, 11:53 AM
Vehicle: 1983 Ford Bronco
That's the starter RELAY; the solenoid is ON the starter.
The problem is that nasty (+) battery clamp. Go to NAPA & buy this:
When you remove the clamp bolt, pull the wire & its ring terminal out of the clamp. Use a wire brush (preferrably brass, but steel if necessary) to clean the ring terminal thoroughly. DO NOT apply grease to it. Attach it securely to the new clamp. DO NOT apply grease to it. Clean the battery post thoroughly & spray on "Battery Terminal Cleaner & Leak Detector", then install the new clamp w/wire.
You won't use the ring terminals included with the new clamp now, but save them for other projects.
Old 07-02-2009, 10:53 PM
Not trying to start anything, but it actually is a solenoid, they're just using it for a heavy duty relay.
Old 07-03-2009, 02:06 PM
No, that type of relay contains a solenoid, but they're not the same thing. Check that Ford diagram & WikiPedia.
Old 07-05-2009, 02:59 PM
Vehicle: 2005 Ford F150
that happens alot with the f150s around here due to the climate, the large battery wire that goes to the starter solenoid corrodes off right at the starter
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
