Fog light wiring harness
on
If you are good with a soldering iron, just make one yourself.
Not that easy to find anymore, but 14 AWG flat 4 trailer wire works well for making driving lamp harnesses.
An inline fuse holder, sized correctly ( 14 AWG pigtails )
You would need the wire, some 9145 bulb connectors ( Autozone usually has them, calling them a "harness upgrade" which is just a male to female pigtail ) and a relay and switch of your choosing.
The diagram with a standard auto / Bosch relay is simple :
Just remember to use a good ground ( like the one for the headlamps on the fender, not the driving lamp mount ) and use heat shrink with the solder joins ( I prefer marine heat shrink with the sealant in it ) and get a relay large enough for the load + 20%, and try to stick with 14 AWG wire.
Size the relay and the fuse for 80% of the continual load.
If you have 2 x 55 W lamps, this is 110 W or 110/12 = 8.7 AMPs.
This means you should use a 15 A fuse in the harness, and at least a 20 A relay.
You can get the factory headlamp switch with the fog lamp option if you want, bit more work on adding the connector to the headlamp switch, but easy enough if you have a bone yard nearby with a truck in the same MY range as yours.
Let me know if this helps.
Look hard for secured connectors tucked away.
It is a possibility that the wiring you need is already there. They consolildated alot
of features to be incorporated into a universal wiring harness for many different vehicles.
Mine didn't come with fog lamps, (99 F-150 XLT) but the switch has the fog lamp function and the wires are behind my front bumper. The wires are there if I wanted to add them to mine, and they are functional when the fog lamp relay is added. Double check before going through the trouble of wiring them up..
FordMasterTech
FordMasterTech
I had to order the headlamp/foglamp switch as mine didn't have the switch. I had the relay and the wire from the switch to the relay but that was it. I found the connector where the foglamp wire should have come out of but it wasn't there. I made my own harness and used an aftermarket relay. I tapped into the foglamp switch wire and ran it over to the aftermarket relay so I can have the driving lights on with the high beams.
on
Don't bother looking for the harness, that stopped in 2003. 2004 +, unless the truck is ordered with them, the harness is not complete.
No switch in the above diagram. The wire to terminal #85 is connected to the low / high beam wire ( which ever you want them to come on with ).
Same thing, the relay for the HID fog lamps ( as diagram above ), terminal #85 is connected to the trigger wire for the HID headlamps.
on
Which harness part number did you order ?
The fog lamp harness to the Central Junction Box is one continuous harness to connector C270A
Some have already had the fog lamp connectors by the bumper, but the part that always seems to be missing is the wiring from the main headlamp switch to the CJB, to turn on the fog lamp relay.
I have seen quite a few threads in the 2004-2008 forum on this topic. Don't know if someone figured out how to add the wiring from the switch to the CJB. This is the White w/ black stripe wire .
The wiring I got was to a F250, I had to alter the harness, but it will work. I have the ford fog light switch, all I need now is the info to make it work. Is the relay in the wiring for the light switch? Which wire goes from the switch to the fogs? Dying to make this mod operational. This is a call to the community...help.
on
How did you alter the harness ?
Altering will change how it works, so the directions or factory wiring for the Super Duty fog lamps is out the window with what you altered about them.
What relay are you talking about ? The F-150 the relay is in the Central junction box, the Super Duty the relay is in the Smart Junction Box.
You got the wiring for the factory fog lamps, or the wiring for adding fog lamps to a SuperDuty without fog lamps ? Did it come from Ford ?
on
Not sure what you mean by :
Do you mean to say you extended the distance between the 2 bulb connectors ?
The F-250 harness does not plug into the switch, it would plug into a connector by the fog lamps ( C134 ) , that takes the wiring to the SJB ( Smart Junction Box ).
What you really have is the bulb connectors, which means you need to get a relay, and make the remainder the wiring harness yourself.
Using this diagram as the basis :
The wiring part you have is from the aux lamps to the splice on each.
The ground you will need to extend and put on a ring crimp terminal. The amount of extension, is depending on which side you run to. Each side has a ground that the headlamps use, this is a good place to ground to.
The power side of the wiring harness, you will need to extend to where you are adding the relay at. This will attach to terminal #87 on the relay.
You need to complete the ground on the relay, and the terminal #30 with a fuse connection to the battery.
The part that is different on the diagram above is Terminal #85 to the switch.
Your terminal #85 will go to the new switch that you purchased. You will need to add pin #9 on the main headlamp switch connector C2150A. This is the White w/ Black stripe wire shown in the diagram above. This might be in the truck already, but usually this is the part that is missing from the Main headlamp switch to the CJB.
So what I did was alter the harness by taking the plug for a foglight and taking the plug for the switch and changing their position.
