Fan blower not working
Old 04-24-2009, 03:45 PM
SSCULLY's Avatar
If the climate seats are not working, you might want to take a look.
The list I posted is what I recall from one thread, this is not the complete list.
The only other check is to see if the power is on the back of the EATC control panel.
If there is power, the next step is trying a different EATC control panel, which is 252.00 + S/H online. That is a part you cannot return if it does not cure it.
If not, you are having to tear into the dash to check.
Might be worth looking at the splices in the door sill, before spending 250 +.
Old 04-24-2009, 04:32 PM
slopoek's Avatar
will check the splices in the door sill per your suggestion. Thank you very much.
If in fact I have to tear into the dash, is there an easy way or procedure to do so?
Old 04-24-2009, 06:05 PM
SSCULLY's Avatar
To get to the EATC control panel, not hard at all.
Pop open the ash tray, and pull the lower corners out. You will see the spring clips. There are 4 on each side, and when you get to the top, you disconnect the PAD lndicator.
EATC control panel is mounted to the center dash trim panel.
Quick Reply: Fan blower not working
