pcm fuse blowing
on
The Fuse F32 has on it
1. EVAP canister purge valve
2. AC clutch relay in the Aux relay box
3. EVAP canister vent solenoid
4. EGR module
5. PVC vlave
6. Cam position sensor
7 HO2 sensor 11
8. HO2 sensor 12
9. MAFS / IAT sensor
in the 99-03 series usually a blown PCM fuse is a sign of a HO2S harness up against the exhaust pipe, and melted through.
Have you done any work around the HO2S or has xhst work done as of late ?
A search in this forum for PCM Fuse would 73 threads.
4. EGR module
5. PVC vlave
7 HO2 sensor 11
8. HO2 sensor 12
Just heading out for the week. No work has been done on the truck at all. yesterday was way to cold and stormy to think about looking at it . I've had people say it's a faulty pcm , but it will restart for a few seconds ten blow the fuse again, others say it's my fuel pump drawing to much amperage. I tend to think it would be fuel pump related or bare wires somewere. Will be back home on the weekend but might just have it towed to a garage and hope I don't get sc@#*ed to much.
I really hate taking my truck to the garage when I am capable of fixing things myself. Chances are if I was driving it when it quit and had time to investigate the problem I might be able to figure it out. thanks for any assistance.
