F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Electrical Systems
Thread Tools Display Modes
Old 06-02-2008, 08:03 PM
Vehicle: 2004 Ford F150
drivers seat, mirros and pedals not working
I have a 2004 F150 Screw lariat and all of a sudden my power drivers seat, power pedals and mirrors are not responding. My passenger power seat, moonroof and power rear slider work just fine. I checked the fuse box and it looks like these things would be under fuse # 3. The fuse was fine. Does anyone know what this could be?
Thanks, Nick
Old 06-02-2008, 08:32 PM
Vehicle: 2002 Ford F150 FX4
might be another fuse controlling those things. i really cant tell you.
get to work with a volt meter and see what you come up with.
2002 F150 FX4. Black two tone. Extended cab.
-SI/DO flowmaster catback
-AFE cold air
-EDGE Attitude. Level 2 Custom.
-Headmaster Shorties. One cat for each side.
-305/70R16 ProComp Xterrains-16" American Racing rims.
Old 06-02-2008, 09:17 PM
Vehicle: 2008 Ford F150
Send a message via AIM to bxstang2000
Check fuse #109. Usually when more than one things aren’t working its fuse related. Even though fuse #3 is good the fuse inline before it might be bad. I just checked out the online manual and fuse #109 30A fuse is related to your problem (Power drivers seat and pedals). I dont have a wiring diagram but this could also be related to fuse #3 which has to do with your power mirrors. The power seat, moon roof, and slider are on separate circuits.
[SIG]
2000 Ford Mustang GT
2008 Ford F150 FX4[/SIG]
Old 06-02-2008, 11:18 PM
just went and replaced the # 109 fuse and that is not the problem.....anyone else? I really dont want to go and pay someone to "search" for this problem and charge me a forune for a "simple" fix.
Old 06-03-2008, 12:49 AM
So both fuse #3 and #109 are good? Have you checked to see if there is voltage at both ends of these fuses?
Old 06-03-2008, 01:57 AM
Quote:
not quite sure how to do that......I know how to use a multimeter, just dont know where to check.
Old 06-03-2008, 02:00 AM
Vehicle: 06 Ford F-150
Pull the fuse out and check if there is voltage on one post with a Voltmeter
Old 06-03-2008, 02:10 AM
Quote:
You could even leave the fuse in and put the one DVOM (volt meter) prong on a good ground and other prong on one side of the fuse then the other side of the fuse. If its a hot fuse you should have voltage on both sides of the fuse. There will be a small gap in the plastic where you could test the fuse (That is where you are putting the DVOM prong). If theres voltage on one side and none on the other the fuse is bad.
You may want to turn the ignition on a test every fuse. If you have a test light this would be a lot easier and quicker.
Old 06-18-2008, 04:07 PM
Vehicle: 2004 ford f-150
its the drivers seat module under seat mind just did the same thing
Old 06-18-2008, 06:34 PM
Site Sponsor
If it is the memory seat module then you are looking for part number: 2C7Z-14C708-BA (has an engineering number of 2C7T14C708AE)
Old 06-22-2008, 03:38 PM
Vehicle: 2007 FORD F150
Wink It's under the seat
Same thing happened to my 04. The wires came loose how it effects the mirrors is beyond me. I checked every fuse all were good. Scratched my head and remembered the power seat plugs in some where?
Old 08-31-2008, 07:05 PM
fix for this problem....
http://www.fordf150.net/forums/viewt...=430100#430100
Old 07-02-2009, 08:25 PM
Quote:
Originally Posted by kegnison View Post
BRILLIANT !!!!!! THANK YOU!!!!!! Took 10 minutes to fix after a whole winter of frustration!!!!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
