Warning Tone / code
on
Originally Posted by Klitch
gotta ask, series of beeps from the passenger side airbag area. 5 beeps per session, 4 sessions some sort of code?
Yes. Your airbag warning light in the dash is burned out AND there is a fault in the airbag system.
The 5 by 5 beep sequence is a backup warning of an airbag system fault.
Steve
bah that thing is gonna get shot. the passenger airbag got disconnected when the battery was connected. but the light still works?? the yeller airbag light in the inst cluster works (irritates me daily!) and the light for the passenger bag on/off works. is there one i missed?
there is no way for me to reset the airbag warning light correct?
code thrown 4-2 / 42
Passenger side crash sensor disconnected? something like that at least
on
Yes. Wire nuts are NOT suitable for automotive wiring. Neither are ScotchLoks (IMO). Use crimped (butt) connectors, or solder & heat-shrink tubing (the best). Ford recommends soldering the 2 wires together side-by-side pointing the same direction with the tubing over ONE wire. When they're soldered, fold one back over the connection, then slide the tubing up & shrink it. That will give you 3 passes of wire inside the tube. Glue-lined tube is preferred for exposed repairs.
on
Have you checked local electronics suppliers? Ford sells a kit to dealerships that includes a bunch of pieces, but IIRC, it's close to $200. You can get away without it - I just said it's preferred. If you can't find it, but insist on having it, just get some tiny hot-glue sticks & wipe one over the solder joint before it cools, then slide the tube up.
