Factory Color Code on '94 Ford F-150
Old 10-11-2006, 06:24 PM
tschaffer's Avatar
I'm looking for the factory color code on a 1994 ford f-150. If anyone has that information it will be very helpful. If you need any information on the truck just ask.
Old 10-11-2006, 06:53 PM
mgsalida's Avatar
Welcome
Not sure if this info will be the same for your 94. I found this from a 97 f150.
You can look at the Vehicle Certification Label (on drivers door or "B" pillar) and look for the paint code.
The exterior paint color codes are:
NOTE: All colors except prime include a Clear Coat (C/C).
NOTE: Two codes indicates two-tone paint.
BA - LT Prairie Tan C/C.
DZ - Light Saddle C/C.
E4 - Vermillion C/C.
JL - Dark Toreador C/C.
KM - Royal Blue C/C.
PS - Pacific Green C/C.
RD - Teal C/C.
TS - Silver Frost C/C.
UA - Ebony C/C.
XC - Portofino Blue C/C.
YZ - Oxford White C/C.
Y1 - Prime.
Hope this helps.
Mike
Old 10-11-2006, 07:24 PM
tschaffer's Avatar
oops
Oop's, Ment to say Wiring color code... thanks for the help though
Old 10-12-2006, 08:13 AM
subford's Avatar
1994 Ford Truck Series wire codes from the EVTM:
Old 10-12-2006, 08:15 AM
projectSHO89's Avatar
1994 F-series EVTM
Color Abbreviations
BL BLUE
BK BLACK
BR BROWN
DB DARK BLUE
DG DARK GREEN
GN GREEN
GY GRAY
LB LIGHT BLUE
LG LIGHT GREEN
NA NATURAL
OG ORANGE
PK PINK
RD RED
SR SILVER
TN TAN
VI VIOLET
WH WHITE
YE YELLOW
NOTE :Whenever a wire is labeled with two colors, the first color listed is the basic color of the wire, and the second color listed is the stripe marking of the wire.
Steve
Old 10-12-2006, 04:02 PM
tschaffer's Avatar
great thanks
does anyone have the schematics of that?
Old 10-12-2006, 06:22 PM
subford's Avatar
For what item?
Old 10-12-2006, 06:25 PM
tschaffer's Avatar
The standard radio coloring,,,, trying to install aftermarket and wasnt quite sure where to post. If this is the wrong location it can be moved, just please provide a link
Old 10-12-2006, 07:37 PM
Adam06FX4's Avatar
Registered User
please dont tell me you cut the factory harness . buy a wiring kit for that truck then all you haveto do is match the colors from the deck to the wiring harness and plug it in!!
Old 10-14-2006, 11:18 AM
subford's Avatar
Old 10-15-2006, 01:42 PM
tschaffer's Avatar
subford
subford, The guy that I was trying to help has sent me the wrong direction...those schematics are PERFECT...But the truck is a 1995 not a 1994(not sure what he was thinking) If that same color code/schematic applies just let me know, if not anything you could do to help me would be greatly appreciated
Old 10-15-2006, 08:12 PM
tschaffer's Avatar
bump
bump
Old 10-16-2006, 07:14 AM
subford's Avatar
1994 & 1995 are the same.
Old 10-16-2006, 04:26 PM
tschaffer's Avatar
thanks for all the help dude
Quick Reply: Factory Color Code on '94 Ford F-150
