airbag light helpe code 32
airbag light help
Hi I have a 1998 F150 and it has a silly sound and also the airbag light in the lower right hand corner of the dash that blinks in a sequence of 3-2 five times and then is on
would you please tell me how to fix that or what do I do?
Angie
Angie
on
Definition:
FC 32/DTC B1932 — DRIVER AIR BAG MODULE CIRCUIT HIGH RESISTANCE OR OPEN
Unless you know what you are doing around the airbag system, it is highly recommended that you leave the servicing of this system to a professional who has the proper training and equipment to diagnose and repair the system.
You didn't mention it, but how are your horn and cruise functions?
Steve
Steve
My 94 Escort had the same code. I took it to the dealer and,without even looking at the car, they told me it was the clock spring in the steering column. I thanked them and then did some research on the problem. I took the car home found a TSB listing about the problem, obtained a copy of the TSB and then checked the circuit IAW the TSB. It seems that if the air bag circuit resistance gets above 3.2 Ohms the airbag light flashes a 32 code. I found a connector in the circuit with the pin contact resistance slightly higher than specs. I cleaned up the pins and applied a little dielectric grease and haven't had any further problems in the last six years. Be careful! Follow all precautions in the service manual (Haynes) before working on the air bag circuit. If you don't disconnect the battery and wait a specified period of time for the circuit back up power supply to discharge you could inflate the air bag, and that is dangerous and expensive. By the way, the TSB for the Escort is TSB 95201. If you can get a copy of it, it may give you some insight into your problem although it will not be a direct reference for your vehicle. Good Luck and BE CAREFUL!!
i have the same porblem in my 94.... and my horn a curse dont work..... also if i turn on my windshield wipers on, they will only work in low and high (if i turn it just right) and they wont go off till i shut off the truck.... dont know if the wipers have ne thing to do with that.... but does that sound like the clock spring?
