1997 4.2l 2wd pcm fuse blown
Old 07-22-2006, 09:50 PM
bobzz's Avatar
hope someone can help...fuse #24 engine block PCM fuse blown...I was drving along and truck quit..pcm fuse blown #24..replaced fuse and drove about 20 miles...fuse blown again..replaced and drove about 3 miles then blown again...replaced and fuse blows now when installed...unplugged the computer but fuse still blows...somewhere their is a short..any ideas...hope someone can help...thanks
Old 07-22-2006, 11:27 PM
bigspuds's Avatar
just had the same problem with 2000 f150, unplug your pcm relay and replaced fuse, it quit blowing, so used ohm meter and started checking for grounded components, found the egr pressure sensor bad, unplugged it and replugged relay and fuse did not blow, replaced sensor and truck has ran good ever since, and mine did same thing it quit, ran for 20 miles, then i hit a bump and then it started blowing fuses until we found problem hope this helps
Old 07-23-2006, 12:17 AM
bobz's Avatar
Thanks I will check out tomorrow and let you know,,,
Old 07-23-2006, 12:34 AM
bobz's Avatar
I did unplug relay and the fuse quit blowing...
Old 07-23-2006, 08:51 AM
bigspuds's Avatar
ok pull your air intake stuff off, looking from front of truck on your right side there is a silver box with an oblong connecter, and i think three hoses, it is an egr pressure sensor or egr vacuum regulator (don't know what it's called) and unplug that, go ahead and plug your relay back in if fuse does not blow that is your problem, i paid about $44.00 for it, hope this info helps, Good Luck, all this electrical stuff can get nerve racking and fuses can get a little expensive. Also if you have an ohm meter thats a plus, that will save your fuses, Going to church right now will check back when I return, good luck
Old 07-23-2006, 12:38 PM
projectSHO89's Avatar
F24 Short Circuit
Please read this thread in its entirety: https://www.f150online.com/forums/sh...ghlight=f24%2A then read the followon thread https://www.f150online.com/forums/sh...15#post2175215
Please notice how many circuit devices are on this fuse, so don't focus solely on the DPFE sensor as mentioned.
You really need an ohmmeter....
Steve
PS. Check the O2 sensor harness first to make certain they haven't melted onto the exhaust...
Old 07-23-2006, 03:03 PM
bobz's Avatar
went to bone yard and got 2 dozen 30amp fuses....started to unplug sensors one at a time,,,,,started with egr then unpluged passenger side oxygen sensor ..fuse #24 did not blow....sensor was good....problem was a pinched cable running across top back of engine..feeding both oxygen sensors..
thanks for the help it started me in the right direction ......these so called mechanics around here charge 65.00 hour just to look..
Old 07-05-2021, 12:50 PM
Jeff777's Avatar
Hey
Hi are you still around?
Old 07-05-2021, 01:58 PM
glc is offline
Hasn't been here since 2006.
Quick Reply: 1997 4.2l 2wd pcm fuse blown
