Ground upgrade??
Old 03-24-2006, 12:11 AM
slowtan's Avatar
Ground upgrade??
I am going to be upgrading my stereo system and was reading about changing the ground wire on the Alt , starter , battery.
My question is what am I doing? Just replacing those grounds with some 0 guage wire? Is that it? Does this really help. I have an 03 Supercrew w/about 1300 watts in total power going in + new head unit .. or should I just get a cap. Some people like caps and others say they are junk .. It just baffles me and I don't want to waste my $$.
Old 03-24-2006, 03:55 PM
Sarge97's Avatar
I would say go for it. The more current flow you can get in your system the better. All my years in car audio I finally stepped up and upgraded my wiring in my current truck and the difference was noticible. Although now I have a 200 amp powermaster alt and 2 batteries, which helps. But if you are running some good stuff in your truck I would say do it. Ohm out all your connections and make sure they go low. Cover your exterior grounds with some good grease and you should be good to go.
Quick Reply: Ground upgrade??
