Old 04-13-2015, 12:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
Is your 'door ajar' or 'dome light' staying on? Forum members suggest various methods that they fixed their issue. The methods include:
          Read the full discussion below to find out the preferred method.
          Print Wikipost
          If your "door ajar" or "dome light" is staying on, Read this.
          Old 07-23-2005, 06:13 PM
          zapster's Avatar
          Originally Posted by lees99f150
          Since people are always asking how to fix their dome light or door ajar light from staying on. I thought i would make a post showing how to fix it.
          If the light is on and the doors are shut then spray some WD40 in to the latch. The door switch is probably stuck.
          Spray in both doors then open and close them a few times. sometimes you will need to spray a lot of WD40 and it will run out the bottom of the doors. Just leave them open until it drains out.
          thats exactly what brought me here to f-150.com back in janurary in the first place
          ...zap!
          Old 07-28-2005, 04:11 PM
          Paul Siciliano's Avatar
          Originally Posted by f150sc04
          still no luck .sprayed all 4 locks and unpluged all doors. guess it will go to the dealer
          When you spray use the spray straw and point it well up into the lock area where you can't really see. That's all the dealer is going to do to get your $500!
          Old 07-28-2005, 04:30 PM
          I indicated earlier to spray with the spray straw. I used Fabulous Blaster by PB. It's a penetrating catalyst!
          Old 07-30-2005, 07:53 AM
          toomanybike's Avatar
          ohhhh boy
          thats been bugging me for years......thank you...i always was soo dang frustrated...at work everyone would tell me my lights were on..i would always have to say they turn off in like 20 minutes
          Old 07-30-2005, 01:44 PM
          99Flare's Avatar
          Its just not the F150's. My wifes 97 Taurus had the same issue wtith the domelight staying on from a sticking latch switch. WD 40 works everytime. Great thread!
          Old 12-17-2005, 08:06 PM
          98Navi's Avatar
          I know this thread was all but dead, but Ihad this problem on my navi that had gotten so bad I was pulling the fuse to stop it. I then tried this (long before I knew about this site, damnit) and slammed the doors a few times and now it only happens intermittantly every few months and even then it usually goes away. The guy at ford told me the switch was magnetic and that they frequently had this problem. Slam the shiat out of it once you have sprayed it real good, and if that doesn't fix it, take it and get it fixed. Its an aggravating SOB
          Old 12-17-2005, 08:55 PM
          Gator.'s Avatar
          Worked for me!! Thank you very much!!
          Old 12-19-2005, 06:08 PM
          lizard101470's Avatar
          Worked here also. thanks for the help!!!!
          Old 02-24-2006, 12:56 AM
          99fordman's Avatar
          I'm glad to know I have a honest mechanic, if there is such a thing! lol I had the dome light problem about 8 months ago. So I took it in to the mechanic and he called me and told me it was fixed free of charge. He actually showed me this neat little trick too. I was impressed with his honesty!
          Good thread it works every time!
          Old 03-07-2006, 06:35 PM
          Grey CJ's Avatar
          Talking
          Thank You!!!! Thank You!!!! Thank You!!!!
          I just did this WD-40 trick last night on my 99 F-150 and it worked awsome!! This had been driving my nuts for 3 weeks that I pulled the 15A fuse, but I couldn't put the windows down b/c there on the same circut. I was so close to biting the bullet and droping my truck off at the local "stealership" to fix.
          Anyway no need to pull the fuse to get the dome light to go off anymore
          Old 03-08-2006, 04:57 PM
          exp.limited edi's Avatar
          Originally Posted by kitrhs99
          My Dad's 2001 Subercab 4x4 is doing this. I was wondering if this is happening on all models and trim levels.
          well my dads expedition is doing this too it probably is on all fords from around 97 and up
          Old 03-11-2006, 04:20 PM
          xibbumbero's Avatar
          In light of similar probs in various Ford models,I'm surprised FOMOCO has not addressed this issue. X
          Old 03-11-2006, 05:37 PM
          chester8420's Avatar
          To the people that tried this and it didn't work: Try using ether(starting fluid) instead of WD-40. WD-40 worked on my truck, but not on my uncles. We used ether and it fixed it.
          Old 03-11-2006, 05:57 PM
          Dog'em's Avatar
          I had the same issues with my 98 scab, tried the WD40 along with everything else I could get my hands on with no luck. Finally ended up replacing the $10 relay in the fuse box and have not had a problem since.
          Old 03-12-2006, 02:24 PM
          jpgillespieusa's Avatar
          this worked great but now
          I used the wd-40 trick and low and behold the light went out. It was driving me nuts...
          Now I notice that the light will stay on ocasionally until I turn the key to the on position then it goes out.
          Any ideas?
          Jimmy
          Quick Reply: If your "door ajar" or "dome light" is staying on, Read this.
