F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Electrical Systems
Thread Tools Display Modes
Old 07-18-2004, 07:46 PM
Vehicle: 2002 Ford F150
Door open chime
New to forum and really enjoy all the Q&As I have read.
Is there a way to turn the key to aux and play radio with the doors open and not have the chimes going off?
Thanks,
Frank
Old 07-19-2004, 03:49 AM
Vehicle: 1993 Ford f150
Well my ignition system is a really strange one. Many many problems none of them serious problems theyre more like oddities. Anyways mine doesnt chime with the door open unless I jiggle the key and then It wont shut up so I just dont touch the key once its open. If I were you Id put a piece of tape over that pin that sticks out that tells the buzzer when to buzz
Old 07-19-2004, 09:05 PM
Send a message via AIM to referee77 Send a message via Yahoo to referee77
I was wondering the same thing myself. The door open/keys in the ignition chime should ring only if the key is in the off position, not the AUX position as well. It's a pain in the butt when I want to hear the music outside of my truck with the door open, or if I am sitting in a parking lot and want to have the door open and still listen to music without the stupid chime ringing.
Does anyone have any ideas other than taping the pin on the door?
Is there a fuse that can be pulled?
A wire that can be cut?
Thanks,
Ken
Old 07-19-2004, 09:18 PM
Thanks,
Ken
Old 07-19-2004, 11:12 PM
Vehicle: 2004 Ford F150
Send a message via AIM to Quintin Send a message via Yahoo to Quintin
Well, a temporary solution is jamming the upper door latch shut with a screwdriver, and remembering to pull the door handle to unlatch it before you slam the door.
Or you can cut the wire to the key chime switch and tape it back into the harness out of the way. Or you can remove the pin at the connector at the GEM that provides the key chime signal.
Old 11-15-2006, 07:08 PM
Vehicle: 1996 Ford F150
Cool
Hi, I hate that door chime Too. i don't know how to unhook it permenently but on my truck if you pull the fuse for the speedometer it kills the chime to.check the dash fuse panel.
Old 06-30-2009, 03:15 PM
Vehicle: 2008 Lincoln Mark LT
So what needs to be cut or removed? does anyone have detaild instructions on how to cure the ever so anoying door buzzer.
Old 06-30-2009, 03:49 PM
Vehicle: 2005 Ford F150
Quote:
You just resurrected a 3 year old thread. Did you read through it? There's ideas in there. Why not actually read them and try them, specifically post #5?
Old 06-30-2009, 04:12 PM
Vehicle: 2004 Ford F-150
I was under my dash this weekend and saw what I suspect is the dinger/truck speaker for the random noises it makes. No sense for me to take it out as I don't mind its conveniences. It was under the dash, kind of near the flashing red light/light sensor for automatic lights. It was way up there. You can see it if looking up with the knee panel removed. I wouldn't cut it though.
PHP Gryphon, 2.5" AS level, Strobes on all 4 corners, Black TS Toolbox, 15% tint all around, Pioneer AVH-P4100 with Low_e_red's relay bypass, MA Audio 1000w RMS 1 ohm amp pushing 2 - 10" ED subs under the rear seat, Viper 5901 with 530T auto up/down windows, Viair 380c at 165/200 PSI in a 3 gal tank pushing 1/2" DOT airline to my Siege Engineering train horns, and Beltronics RX 65 pro to keep me out of trouble
Old 06-30-2009, 04:52 PM
Vehicle: 2006 Ford F150
Quote:
always has to be someone............
Old 06-30-2009, 06:25 PM
Vehicle: 2006 FORD F150
The chime you are talking about is the key in Ign one correct ?
Do you want it gone for good, or able to be turned on and off ?
There is the method of putting a switch on the door latch circuit, so you can turn it off ( truck will think the door is always closed ).
Don't know which way you would rather go.
BTW : mtylerb's reply is not typical of the members here.
Old 06-30-2009, 08:35 PM
Quote:
Originally Posted by SSCULLY View Post
... BTW : mtylerb's reply is not typical of the members here.
Lol, he's right. I'm usually a nice person, but I read the thread and saw around 3 different options in post #5.
Anywho, listen to SSCULLY, the guy has way too much electrical knowledge of these trucks. Seems to know what he's talking about.
Old 06-30-2009, 11:00 PM
...<snip>...
3 options, ok :
1. Trip the door latch with a screw driver
2. Cut a wire ( no indication of which one )
3. Pull a wire from the GEM. ( no indication of which one )
OK, read his post
So what needs to be cut or removed? does anyone have detailed instructions on how to cure the ever so annoying door buzzer.
See where kurtlandwehr has a very valid question ?
pointing him back to post #5, which caused the question in his post, is a circular definition
Old 06-30-2009, 11:39 PM
... Anywho, listen to SSCULLY .... Seems to know what he's talking about.
... See where kurtlandwehr has a very valid question ? ...
I rest my case, listen to SSCULLY.
Old 07-01-2009, 07:58 AM
Quote:
Originally Posted by yetti96 View Post
I was under my dash this weekend and saw what I suspect is the dinger/truck speaker for the random noises it makes. ...<snip>....
Just waking up, and caught this. Do you have the parking aid installed on your truck ?
This sounds vaguely familiar to the location for the speaker for the parking aid.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
