F150 V8 SCT X4 Tuner
Hi all,
I upgraded tires on my stock rims to 285/70/17 Nitto Grappler 2 and bought an SCT x4 tuner to adjust tire size. I programed it to the stock 87 octane and plugged in my tire revs. I got more power with bigger tires and same if not a little better gas mileage. The only problem is it seems like it holds 1st gear for a long time up to 10mph and tries as quickly as it can to get into 6th gear around 40mph. I feel like the engine bogs down to easily. I think I can make adjustments to gears utilizing the WOT shift option on the X4 tuner along with my 87 octane tune. Does anyone have any suggestions or know what I should adjust this to? 1-2 gear is currently set to 0mph, you can go up to 7mph or down to -3mph (not sure what that means?). Same settings for 5-6. Any advice would be appreciated. Thanks!
