Go Back   F150online Forums > Powertrain & Mechanical > Chips, Tuners & Programming
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Chips, Tuners & Programming SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 12-09-2009, 01:19 AM
Garage is empty, add now
Vehicle: 2010 Ford F150
Question **Cold Air Intake vs Programmer**
Which one will give your truck the most power??:santa:
Old 12-09-2009, 01:21 AM
2004 Ford F-150
Vehicle: 2004 Ford F150 5.4
Send a message via AIM to TruckGuy24
Programmer.
Old 12-09-2009, 01:39 AM
2010 Ford F-150
Programmer by far.
2010 F-150 4x4 3.73 LS 3V 4.6l
Old 12-09-2009, 09:41 AM
2002 Ford HD #04417
My Garage
Vehicle: 2002 FORD/HD #04417
Programmer/tuner!
Old 12-09-2009, 09:54 AM
2008 Ford F-150
Vehicle: 2008 ford f150
Send a message via AIM to timmypstyle
i wouldnt trust a programmer without doing either an intake or better flowing exhaust first tho. i dont have a programmer but i do have an intake. intake will add some liveliness but its only about 5-10hp. mostly throttle response is the waking up it does. programmers apparently add about 20hp or so. not sure since i dont have one but the intake is a good thing to do too.
BEST 1/4 MILE TIME-16.9378@81.66mph-with intake only
2008 F150 reg cab shortbed 2wd 4.2L V6 5spd, 3.55LS, Yokohama Geolandar AT-S 235-70-R17
PERF MODS-VMP 87 performance tuned SCT X3, K&N 77series CAI with helper tube from front bumper, scangauge2.
VISUAL MODS-projector headlights with halos, tinted tails and 3rd, 09-13 emblems.
Old 12-09-2009, 10:00 AM
2005 Ford F-150
Vehicle: 2011 Ford F150, 5.0
Quote:
Not sure what you mean. A programmer certainly does not need a CAI. It is the other way around. You don't get full benefit from a CAI and on some engines run the risk of running lean without custom programming.
A tune can add 20 to 30 hp, depending on if it is canned or custom and which engine. A CAI without a tune will do good to add 7 or 8. That can be doubled with a custom tune.
Old 12-09-2009, 10:45 AM
2008 Ford F-150
just because your stock air intake and exhaust are restrictive, making your engine run with more power without modifying anything is what i have a problem with. doesnt seem right if adding an intake helps out with power and mileage just from letting the engine get more air, but by adding a program, you get the same result but still have less airflow. seems like you are tricking your computer into getting something it doesnt get. seems it would have to sruggle to suck air from a paper filter in an enclosed box. with an intake, it has the high flow filter to suck thru and open area for the air to come in. IMO i would not get a programmer without an intake and/or exhaust upgrade first, intake first but preferrably both. LET IT BREATHE!!
Old 12-09-2009, 10:47 AM
2004 Ford F-150
I don't get what you mean... the programmers improve shift points and make the truck more efficient and more powerful becuase of the conservative factory tune Ford put into these trucks. Now what I did was get my exhaust and DWV intake with K&N done and the Gryphon will be shipped as soon as I submit the bill. I understand that you are saying it makes more of a difference, but it really does no harm to the truck to jsut do a programmer.
Old 12-09-2009, 10:51 AM
2005 Ford F-150
The computer controls the air/fuel ratio. The stock ratio table can't handle all the extra air without a tune that rebuilds that table. You can put a 10 inch tube on it to let in more air, and it will not improve performance more than what the ratio table is capable of doing. You really need to do a little reasearch/reading before giving advice. If you don't do a custom tune, the Gotts mod is more than adequate as it will provide all the air the fuel table can handle. Plus, if you have a 2004 or 2005 5.4, you run the risk of running lean unless you are custom tuned.
Old 12-09-2009, 10:53 AM
2001 Ford F-150
My Garage
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
exactly, a programmer provides much better driveability, if you have a 2 valve motor then do the gotts mod along with a programmer and your truck will drive like a brand new machine (on 91-93 octane) you can use the crappier fuel if you are not tuned for the higher octane and be fine and that's what most people do...
but if your getting a tuner/programmer why not get the best bang for the buck
-LOTS OF PARTS FOR SALE http://www.f150online.com/forums/par...-new-post.html
Old 12-09-2009, 12:01 PM
2008 Ford F-150
i dont disagree with all of you. basically just saying that I would never put a programmer on without doing at least the intake first. just dont trust it alone. no matter what you say, you cant change my mind. but since i already have an intake, a programmer would be next, just dont have the $ right now. working on my exhaust. wont be any better flow, just going for looks. i have not heard any exhaust system that is worth buying and putting on the V6. its still a V6 and you can still tell its a V6. my stock system sounds fine to me so i am keeping it. just re-routing it after the rear axle so it is 2 pipes out of the back.
Old 12-09-2009, 12:09 PM
2005 Ford F-150
The problem is that your advice to the OP is not only worthless, but is dangerous in some cases. What you do with your own truck is your business and not a problem. I have run a programmer now for 64,000 miles with no CAI. It is awesome. I could add a CAI with my custom tunes and get maybe 6 or 7 more HP. Not cost effective since I am not racing anyway.
Old 12-09-2009, 01:47 PM
2001 Ford F-150
My Garage
Vehicle: 200? FORD
well do not offer any advice to anyone expecially someone with an early 3 valve motor, your "advice" would end up costing someone a motor and maybe more...
Old 12-09-2009, 11:16 PM
2010 Ford F-150
My Garage
sorry, and I don't intend to try and change your mind but I'll just respectfully tell you that you're wrong.
I just installed my Gryphon tuner (canned 87 tow tune) on a bone stock 2007 5.4L. It's like driving a completely different truck. Throttle response is much better, shifting is vastly improved and it's got a ton more get up and go. I can't wait to get my custom performance tune.
Old 12-10-2009, 04:54 AM
Vehicle: 2004 ford E-250
Quote:
jim, he'll argue with you all day long, he's the type that believes everythinmg he reads in a magazine is true,like 1/4 mile times,ie-post -"went to the track" in the non street racing forum.
2004 E Series Super Duty VANGINA
-SCT x-cal 2
-ASP Underdrive pullies & Goodyear Gatorback Belt
-Magnaflow 2 1/4" SS, x-piped,mandrel bent dual exhaust-#14335 mufflers
-Tru-Cool V-10 40,000 lb gvw transmission cooler #4379
2006 Honda CBR1000RR-157.2 rwhp,82.5 ft.lbs.tq
2011 Ktm 450 SXFs-+25,Vet A,+40 A
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
