F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Chips, Tuners & Programming
Chips, Tuners & Programming SPONSORED BY:
Thread Tools Display Modes
Old 11-02-2009, 11:10 AM
Location: Among javelinas and scorpions near Tucson, AZ
Vehicle: 2005 Ford F150
Quote:
Originally Posted by AntzFreshWhip View Post
Ok. I get it today so hopefully when I get home I can hook it up and see what it's all about. I guess the 1st thing I should do when I get it is download Pegasus?
I won't hurt to download and install Pegasus, but you WILL NOT need it until your custom tunes are written. That application will put your custom tunes into the Gryphon.
When you get your Gryphon, all you need to do is this.
1. Mount it on the dash and run the OBDII cable down near the OBDII port.
2. Turn the ignition on - but do not start the truck!
3. Plug the Gryphon's OBDII cable into the OBDII port - the Gryphon's screen should light up and you should see your truck's hex code. Write that down so you can send it to PHP.
4. Push the <menu> button, select "Power Programming", choose Level 2, BYPASS the "Custom Options" selection this first time and let it complete the programming session. It will take about 15 seconds to complete.
5. Drive your truck and enjoy its new "feel".
- Jack
Old 11-02-2009, 12:47 PM
Vehicle: 2006 Ford F150
You'll be fine. I had an 01 with the 5.4, CAI and a programmer and I didnt have any trouble at all.
Funny thing is one of my company trucks is an 04 with a 5.4 and CAI and we've put 200k miles on it and never had any problems.
Old 11-10-2009, 01:23 PM
Quote:
Originally Posted by cstanek View Post
To be clear, the problem is not the combination of a CAI and a programmer.The problem is the combination of a CAI with an 04 or 05 5.4 engine.
To be clear, you are wrong. Any change, no matter what application, to the MAF sensor needs to be tuned.
Based on your [wrong] information, that would mean the JLT intake and my truck doesn't need to be tuned, since it is not a 04 or 05.
Old 11-10-2009, 06:25 PM
Vehicle: 2008 ford f-150
i agree. its like the maf sensor would need to be re-learned in order to work 100% more efficient .
Old 11-10-2009, 08:13 PM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
^^^ you two, wow, just wow, I have nothing nice to say so I'm not gonna say anything
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
Old 11-10-2009, 09:26 PM
Quote:
???wat u talkin bout? all i agreed with him on was re-tuning the sensors..
Old 11-10-2009, 11:07 PM
Yes, the 2004+ F150s are more susceptible to maf housing changes to create lean conditions but it's the same principle with all of these trucks that run ODBII systems. I wouldn't want to run it for an extended period of time. Besides, you're not making full use of the potential of the cai without a tune.
What do you mean? i.ride.suzuki is exactly right.
2006 F150 King Ranch 4WD | VMP Tuning Xcal3 | Magnaflow Exhaust | S&B CAI | E-Fans
Old 11-10-2009, 11:16 PM
yep...thank you...
Old 11-17-2009, 11:09 AM
The point I was making was that it isn't the combination of a programmer and a CAI that can be a problem; it's the CAI. Like I stated above, the 04 and 05 5.4L engines come from the factory in a near-lean condition, so adding a CAI to those engines can "push it over the edge" into a fully lean condition, which can potentially cause knocking and detonation. I never said that a CAI on a non-04/05 engine shouldn't be tuned or that benefits wouldn't be realized. In fact, I didn't specifically mention any years other than 04 and 05 because, based on what I understand, those are the only years where leanness is a problem.
To be clear, the problem is not the combination of a CAI and a programmer. The problem is the combination of a CAI with an 04 or 05 5.4 engine. Ford engineered those engines to run in a nearly lean condition from the factory, so adding a CAI to this scenario pushes it over the edge. Adding a programmer like the Evo doesn't help, but it also doesn't (significantly) hurt. The solution, like has been mentioned many other times, is to get a custom tune to account for the increased airflow.
Quote:
Originally Posted by Bluejay View Post
First, you should not have the lean problem. It's possible, but not likely. The main problem is with 2004-2005 5.4s.
Level one is just a shifting tune, no additional power. Level 2 is a towing tune, a lot more power in the lower end. Good for towing and around town. level 3 is your high performance tune and really the one you want to play with.
Keep in mind that you do not get the full benefit of the CAI with and Edge's canned tunes. You need a custom tune for that. The Edge program is written for a stock intake.
Quote:
Originally Posted by justinj702 View Post
im getting a cai in the next few weeks and also getting a edge evo programmer. ive seen a lot of people say that if you have a cai and get the programmer you will run into problems but that was with 04 and up trucks.
will this happen with a 2001 and will i get the hp and torque from the tuner if i dont use the performance level and just use the 1st and 2nd levels?
2005 Supercrew Lariat 4x4
Quote:
Originally Posted by Rockpick View Post
Having been around here for quite some time now, it's become VERY evident to me that some people just aren't happy unless they're thread crapping. It's really that simple.
Old 11-17-2009, 11:32 AM
Vehicle: 2008 Ford F150
Sorry to somewhat hijack this thread, but I have an Edge Evolution related question. '08 5.4 S Crew Lariat.
I'm running the level 3 performance tune. Everything seems to be working great except for one thing. The speedometer calibration doesn't seem to be making any difference. Every time I try to re-program it and input the correct tire size for my 31-inch tires, it doesn't save it and therefore there's no change. Even if I return to stock and start the whole process all over again, the computer isn't storing the new tire size.
I must be doing something wrong but for the life of me I can't figure it out.
And just for everyone's information, I'm running a K&N intake with zero issues.
Tony
Old 11-17-2009, 12:18 PM
See my response about this in the other thread, Tony. If you have 31" tires, I'd try a Tire Size (TS) of 2400mm. This would be the circumference in millimeters with about 3% squish. Make sure your Gear Ratio (GR) is set correctly too.
- Jack
Old 11-17-2009, 11:47 PM
Quote:
- Jack
I did, thank you. Why in the world would my GR be off? Heck...I don't even know what my GR is, nor did I think I would NEED to know. LOL
And BTW, I have 35-inch tires, not 31. My bad.
Tony
Old 11-17-2009, 11:57 PM
Tony
because it has been known to happen that the default is not what you really have. I had that problem.
Flowmaster 40, K&N dropin, Tint, Roush wheels, 305/50/20s
Edge Evo with PHP custom tunes, GF 2" shackles
Old 11-18-2009, 12:17 AM
Tony
OK, Tony -
For 35" tires, your diameter is 35 x 25.4 = 889mm. The unloaded circumference is 889 x pi = 2793mm (rounded to the nearest mm). Accounting for 3% "squish" you would enter 2793 x 0.97 = 2709mm for TS. (This is much higher than the "default" value you're seeing).
The Gear Ratio (GR) is something else you have to verify and reset if necessary anytime you open the custom options menu. You can find YOUR GR in the VIN sticker on your drivers door under the word "axle" as a code. Here are the codes:
19 = 3.55 open
H9 = 3.55 LSD
26 = 3.73 open
B6 = 3.73 LSD
27 = 3.31 open
18 = 3.08 open
25 = 4.10 open
B5 = 4.10 LSD
Mine is "B6", so I make sure it says 3.73.
Hope this helps.
- Jack
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
