F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Chips, Tuners & Programming
Chips, Tuners & Programming SPONSORED BY:
Thread Tools Display Modes
Old 10-26-2009, 01:37 PM
Location: Among javelinas and scorpions near Tucson, AZ
Vehicle: 2005 Ford F150
Quote:
Originally Posted by F150man21 View Post
thanks for the info, but thats another dilemma im having my door jam says 50psi in the front 60psi in the rear, and my POS tires only fill to a max of 44psi(which is what i have them inflated to). making this evan more annoying.
This sounds like you have "aftermarket" tires? I don't think Ford would have put that sticker on the door, and then installed lower rated tires. Regardless, if you can only inflate to 44 psi, you MAY have to use a higher "squish" factor. Notice I said "MAY". Your tire sidewall construction may be "stiffer", which would compensate for the lower pressure. In any case, the "squish" compensation is a bit of a trial and error value. As you know, Bluejay uses 4%, and I found 3% was right for me. You have to experiment a bit.
- Jack
Old 10-26-2009, 05:13 PM
Vehicle: 2000 Ford F150 7700
haha yea there after market tires. thanks for the help
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
