Quote:
Originally Posted by jawdropperperformance
dirty little secret they don't tell you about handheld programmers that cost up to 15x as much as your jawdropper performance module is that they will void your factory warranty. Handheld programmers work by deleting and rewriting your factor computer's programming. During this highly technical procedure, often the ecu is damaged or the software is not completely loaded. When this happens, your vehicle's $3000 computer is junk and needs to be fixed by the dealer. The problem is, when you take your computer to be fixed, the dealer will use a their computer to interface with yours. Instantly they will be able to detect these changes and will void you warrantee!
OMG! My ECU must be damaged by now then. I have been playing russian roulette all this time! Someone needs to remove people like this from the gene pool...
I salute the OP since they were smart enough to ask the question!
English as a third languange doesn't help either...
All your ECUs are belong to us!
