F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Chips, Tuners & Programming
Chips, Tuners & Programming SPONSORED BY:
Thread Tools Display Modes
Old 09-02-2009, 07:23 PM
Vehicle: 2005 Ford F150
Thoughts and Opinions
I am ready to get a programmer for my rig for many reasons, probably the same as the rest of you. My question is which one has the best range in the sense of best gains, and also a good fuel saver program. I run 35" tires and have after market exhaust and cold air intake. All Opinions and responses are appreciated.
Old 09-05-2009, 06:09 AM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
#1 what gears do you have???
#2 what are you expecting from a tuner??? (you have a gas engine not a diesel)
#3 the gryphon is the most preached tuner on this forum at the current time, the gryphon, sct live wire, sct xcal3 and diablo are the most common ones you will encounter when it comes to custom tunes
#4 custom tunes are the only way to go
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
Old 09-06-2009, 09:21 AM
X2
Old 09-06-2009, 03:42 PM
Vehicle: 200? FORD
I got your e-mail
which engine do you have?
what gears do you have with the larger tires?
Old 09-06-2009, 07:11 PM
Keep in mind that the Gryphon does not really support full custom tuning, it only handles a very limited number of parameters verses SCT and Diablo products. Consider it semi-custom, not fully custom.
2006 Roush F150 FX4 Supercrew
Roushcharger, 9lbs boost - currently running my own tuning.
Dynatech long tube headers w/Magnaflow cats
Troyer e-fan kit. DC Controls and Troyer controllers
Mag Hytec rear dif cover & Level 10 deep tranny pan
2 Intercooler tanks (Roush and Lightning).
Tranny and intercooler fans.
Dash DAQ. Boost, Wideband O2 and G-force gauges.
...and far too many other mods to list.
Old 09-07-2009, 04:58 AM
Vehicle: 2004 Ford F150
define this simi-custom that your talkin about???? ive never heard of this? ive always been under the impression the gryphon could do the same thing a sct livewire could.
2.5 AS, 35" toyo m/t's, maggie true duals w/ rear cats delete and 4"x18" tips, custom sound system, 15% tint, cb&pa system, daylighters in the grill, k&n drop in, hypertech programmer http://www.youtube.com/watch?v=8JGwK0f2-Ms
Old 09-07-2009, 08:36 AM
The Gryphon does not load the entire PCM image into the PCM. That's why its so fast programming (a few seconds verses minutes). It loads a few tables only, the Livewire, XCal 2 and XCal 3 overwrite the entire ROM and can hit all the tables.
Old 09-07-2009, 03:16 PM
I have the 5.4l Triton with 3:55 limited slip on a FX4 SCrew Pkg. I am running 35"x12.5" Tires. Thanks for all the responses but I am still not sure if I know what is the best bet. If I get a custom tune at a shop how much is it going to cost? Versus a Programmer what are the pro's and con's?
Old 09-07-2009, 03:40 PM
Vehicle: 200? FORD
Quote:
wow, that's a lot of tire for 3.55's, you're truck must feel gutless
a custom tune is just that, you can get one emailed to you once you get a programmer that is compatable
personally I use an Xcal2 and an Xcal3 and I like them both but tunes are steep and plan on around $400-$500 depending on which tuning device you go with...
a custom tune will be one specificly for your ECM hex code, your trucks mods and it's intended uses VS a "canned" one that works will all of them
Old 09-07-2009, 03:50 PM
Vehicle: 2006 Ford F150
New gears will make 5x the difference that custom tunes will. Get some 4.56 gears and you will be happy again. Your transmission will thank you as well.
Edit to clarify- I was just saying that you should regear to get a good foundation again, then if you got custom tunes after regearing it would REALLY wake your truck up. Custom tunes do make a big difference but 35s with your high gears are the real problem.
Old 09-07-2009, 09:31 PM
Vehicle: 05' F150 FTX
Im running the VMP tuned Xcal 2... love it, greater response, pwr and mpg's... I think you can get one from VMP's site for $400 with 3 custom tunes.. let me find link
XCal 3
Sig done by Screen-fx.net
Quote:
Originally Posted by LoneRanger93 View Post
I like it, I'm always a fan of little touches like that, which will probably be noticed by 1% of the masses, but truck guys always pick up on it!
Old 09-08-2009, 01:04 AM
Thanks for all the input guys I appreciate it. I think you would be surprised how much power I still get with the 35's. I know I can get more with new gears but that is a little more expensive than a tune, especially with it being 4wd, because from my understanding you can't just do the rear?
Old 09-08-2009, 01:35 AM
Location: Among javelinas and scorpions near Tucson, AZ
Correct! You have to MATCH the front and the rear, otherwise, you have the tires spinning at different speeds at each end. Not exactly what you want for good traction (or good for the drivetrain either).
Of course this is not a problem until you drop it into 4WD.
- Jack
2005 KR 4x4 SCrew 5.4, "Gott's" style CAI, PHP Gryphon Tuned
Old 10-05-2009, 03:48 AM
Vehicle: 2005 Ford Expedition
Quote:
The Gryphon supports full custom tuning just like SCT or Diablo. We have full access to the strategies and can build downloadable, custom tuned files for everything from mild modifications to supercharger applications.
Also, the Grypon changes the entire calibration (maps, functions, parameters) section of the PCM. Just because we do it faster than anyone else is not an indication limited function.
DigitalMarket, I don't know where you get you information from, but you might want to research a little bit better before you post.
Take care.
Bill Cohron - (678) 963-9913 - Gryphon & Evo Specialist
Proud sponsor of F150Online.
http://www.powerhungryperformance.com - The Original in "Custom" Ford Tuning
http://www.phptune.com - Easier to remember this link
http://www.dygytalradio.com - Custom "TUNES" for your ears
http://www.myspace.com/djdygytal - A little more about me
"Palmam qui meruit ferat."
"Amicus certus in re incerta cernitur."
Old 10-05-2009, 09:56 AM
Vehicle: 1998 FORD F 150
^^^^ I assumed the Gryphon had these capabilities. Does the Gryphon have datalogging software like SCT's Live Link?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
