Problems with AdvanceTrack and RSC (Roll stability control) on 2009 F-150
Hi, i did some mods to my F-150 XLT 2009. 3" leveling kit in the front and 1,5" blocks in the back with 35x12,50r17 cooper stt. The problem is that since then the RSC system keeps activating every time a turn in a corner or make an u-turn. Anyone knows why keeps these happening? Hope someone can help. By the way i'm from Chile and Difor (Those are the guys who represent Ford in Chile) don't have a clue about anything.
Thank you,
cblumler.
Thank you,
cblumler.
Thank you,
cblumler.
Thank you,
cblumler.
- Jack
Does de-activating the RSC system help at all? You have to deactivate the system in 2 phases (I believe traction control goes first, then you have to hold down the RSC button for about 10 sec to get the RSC system to go off). I have only done this a few times to prevent the system from engaging in some deep snow.
This may not solve the initial problems, but may be a work around.
2009 Traction Control problem
I have the very same problem ... I have a 2009 F150 4X2 - I installed a 3 inch level system ... Went with 35in tires ... And when you turn downhill to the right - The TC comes on - Only the Right front wheel grabs ... The dealer said they reprogramed the computer with the biggest tire possible - But it was not a 35in tire. They put stock tires on and it stopped. So they said - There was nothing they can do. I modified it. I need HELP! What can I do???
I know this thread is old but I just ran into this issue today with my 2010 F150.. Anyone figure out a fix for a leveled 09+ F150 with AdvanceTrac? Mine went off today when doing a U-turn on a hill so I pushed the button to turn it off and it still happened?
I read that calibrating for the larger tire size with a Gryphon would fix this issue... Anyone have results with this?
I thought someone said SCT could turn off the TC in a custom tune. Someone email justin@vmptuning.com and ask
Again - No tuner or electronic anything will fix this - I tried it all - Went into the computer and reset it to 35" tall tires on 20" wheels - All for nothing - Found the box under the center seat - Changed it's angles with washers - Pulled the wheels off and messed with the sensors - Everything minus pulling my hair out - You can turn off the switch and that works half the time - Or you can pull the fuse out - That works all the time - And the dash light will keep you awake - And you cant sell it like that. Go back to stock or 6" lift kit from Pro Comp - They guarantee it works - And it does - Because they Change all the parts - Keeping the wheels at the exact stock angles. Listen to fact - Or pull your hair out - The choice is yours.
