Go Back   F150online Forums > Powertrain & Mechanical > Chips, Tuners & Programming
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Chips, Tuners & Programming SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 05-10-2008, 08:57 PM
Garage is empty, add now
Vehicle: 2003 ford f150
Question scan gauge
On my truck which is an 03 will the scan gauges trans temp be accurate. Im kinda leaning on getting one but more people have it on later model fords. I would like to see some reviews on some trucks like mine or should they be similar.
2003 f150 supercrew lariat fx4
AF1 INTAKE
XCAL3 BFG 285/70/17
Old 05-10-2008, 09:52 PM
2005 Ford F-150
Vehicle: 2005 Ford F150
Quote:
This is a good question clinr0sp. I have a Gryphon and I monitor the TFT. It seems to follow the oil temp as the engine warms up and then it stabilizes below the oil temp and coolant temp.
The real question here is does a Scangauge (or my Gryphon) get its information from a sensor in the transmission fluid circuit, or is it "inferred", like the coolant temp is from the CHT? I'm betting on a sensor, which would be accurate, but I could be wrong.
Anybody have any input?
- Jack
2005 KR 4x4 SCrew 5.4, "Gott's" style CAI, PHP Gryphon CTS Tuned
Old 05-12-2008, 05:12 AM
2001 Ford F-150
Vehicle: 2001 ford f150 4.6 4x4
i have a 2001 and my ScangaugeII will not show trans temp. i dont think the 1997-2003 computers can monitor trans temp
Mods
K&N drop in
Nerf bars
Line-X Bedliner
BF Goodrich At KO 275/70/16
Upgraded back window to a slider
ScangaugeII
My gas saver is my 2001 Crown Vic p71
http://barackobamasucks.net/
http://www.youtube.com/watch?v=-r1ApR_-bHI
Old 05-12-2008, 07:32 AM
Vehicle: 2002 ford f-150
Send a message via Yahoo to kaboom10
I had a digital temp guage installed. It measures the outlet temp of the trans. The stock factory cooler seems to work great. Truck came with the towing package.
2002 F-150 5.4 L Triton 4x4
Home made CAI.
EBC pads w/Baer rotors SS lines
classic chambered pipe mufflers true duals
4 link and coilover shocks installed
Trans kit w/remote filter and cooler/fan
4.88 gears w/Detroit Trutrac
Livewire tuned w/PRP by me.
Old 05-12-2008, 08:09 AM
where is the sending unit located. Near the cooler or right from transmission.
AF1 INTAKE
XCAL3 BFG 285/70/17
Old 05-12-2008, 10:34 AM
1998 Ford F-150
Vehicle: 1998 Ford F-150
Raptor05121 Raptor05121
Send a message via AIM to Raptor05121 Send a message via MSN to Raptor05121 Send a message via Yahoo to Raptor05121
chris, did you use XGauge and add it on there? It gets all the info from a sensor inside your truck, im not sure if the 97-03's have them, but if your truck is a CAN and program a PWM code, it will read it wrong and vice vera.
-Alex
4.2L V6 - M5OD ~275K miles | SCT XCal3 | K&N Series-77 | 16" Dual Efans | Magnaflow High-Flows
50W 5000K FX-R Projectors | Philips LumiLED Taillights | 60" Plasmaglow Fire & Ice | 2" Drop Shackles
Old 05-12-2008, 12:17 PM
Vehicle: 1997 Ford F150
I have the ScanGuage II and programmed in Trans Temp. My 97 gives the readout and I beleive it to be pretty close. when I first start up in the a.m. the trans temp and the water temp are usually the same. Then as I drive water temp gets up to 195-198 and trans temp goes to 148 - 180.
I also programmed in Horsepower. That one I do not believe at all. It goes allover the place.
97 F150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Live Wires & Coil Packs, Underdrive Pulleys, Troyer Performance Dual 16" Electric Fan Kit, 3.55 LS, EGR Bug Deflector, Retrax Bed Cover, BedRug, XL Full Length Running Boards,EGR Fender Flares, Air Aid Kit, Gibson Single Out Cat Back, Superchips, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks,Expedition Center Console
Old 05-12-2008, 02:07 PM
Thanks fellas
AF1 INTAKE
XCAL3 BFG 285/70/17
Old 05-12-2008, 03:24 PM
2001 Ford F-150
Quote:
mine dont have XGauge
Mods
K&N drop in
Nerf bars
Line-X Bedliner
ScangaugeII
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
