OBD II connector on a 96 ford f150
can anyone tell me where I can find my OBD II connector on my 96 ford f150 5.0 EFI ? Is there one? I found an different style DLC for the self test's. Is that all I got?
I wanna reprogram my computer and from what i can see everything used OBD II connections to do so. And after seeing some of the dyno software and such avalible for my PC i was looking to get a usb to OBD II cable to connect my truck to my PC. But like I said, I cant find my OBD II connector in my truck
On my 03, it is under and behind the panel trimming below the steering wheel. Take a look on yours under there on your truck and look for a sort of a trapezoidal looking port.
Go to the link below and look at that cable above the banner that reads ElmScan 5. You should see a port that looks like the female end of that cable.
http://www.obd2cables.com/products/
Originally Posted by Bluegrass
You don't have OBDII.
You can't do any easy reprogramming of the 5L ECM.
Then have fun reading this:
https://www.f150online.com/forums/sh...d.php?t=299813
