F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Chips, Tuners & Programming
Chips, Tuners & Programming SPONSORED BY:
Thread Tools Display Modes
Old 01-22-2007, 09:46 PM
Vehicle: 1997 Ford F150
I still do not know where exactly to find my axle code...there are a lot of numbers on the diff and transfer case and door panel...is it in the vin too?
Old 01-23-2007, 01:43 PM
Vehicle: 1997 ford f150
there is a small metal tag attached to a cover bolt on your rear diff, it will be stamped with the gear ratio and i think it states whether or not it has a lsd. IIRC mine says 3 55 L and i have a 355 with lsd
Man,I wish i had a v10 f-150
http://www.f150online.com/galleries/....cfm?gnum=7988
Old 01-23-2007, 02:09 PM
Vehicle: 2004 ford F-150
Speedo
tHE ONLY PROBLEM i HAVE WITH THAT MIKE IS THAT THESE GUYS ARE RIGHT ABOUT THE 04-05 AND UP F-150S SEEM TO BE PUTTING MILEAGE ON THE SPEEDO THAT IS NOT WARRENTED. I HAVE A LATE MODEL 04 SCREW AND NEVER RAN UP 18000 MILES A YEAR UNTIL THIS TRUCK.I BEEN NOTICING THE MISCALCULATIONS OF MY SPEED AS I GO PAST EVERY ONE OF THOSE SPEED TRAPS.AND I DONT HAVE A PROGRAMMER INSTALLED YET.
Old 02-05-2007, 03:08 PM
Send a message via AIM to Dans4x4F150
cant find codes! look on mettal tag ans say 75w 140 synth oil only!! thats it
98 4x4 Off Road F150 237,000 mile and stil strong.
Old 02-05-2007, 04:45 PM
Vehicle: 2003 Ford F-150
Send a message via MSN to jorlee Send a message via Yahoo to jorlee
Quote:
Should be another tag. Also look at your safety Compliance sticker in the drivers door jab, Find the 2 digit code, and someplace there is a list as to what it means.
Old 02-05-2007, 05:04 PM
thanx 3.55 lsd
Old 10-10-2009, 01:12 PM
Vehicle: 1999 Ford F150
Quote:
It makes the gas mileage look better than it really is.
Old 10-10-2009, 01:21 PM
Vehicle: 2005 Ford F150
Quote:
Dug up an oldie.
Old 10-12-2009, 05:56 PM
Vehicle: 2001 Ford F-150
Send a message via AIM to 31 YNOT
Quote:
Originally Posted by Keith460 View Post
Can't argue with that!
I wasn't bashing anyone from Edge or any other manufacture of Tuners, but it seemed odd that my friends 03 F150 with an Edge tuner had the correct ratio of 3.73 programmed into the VID block from the get go. I believe I was also talking to an inexperienced individual at Edge technical support while everyone else who was knowledgeable was out to lunch. It took him a while to give me answers to my questions as he was obviously looking at a computer screen for my answers. Believe me, I could tell.
All, in all, I'm happy with the results that the correct gear ratio and proper tire diameter are programmed in my Edge.
Glad you cleared things up by explaining the actual programming process Mike.
if his truck is an 03 it should have 3.55 gears in it. Im sure your truck's PCM has always been right it has just not been correct in the tuner which threw your speedo off. Its just because you didnt put the correct gears in the programer when you reprogramed the truck.
Old 10-12-2009, 06:02 PM
Vehicle: 2006 Ford F150
Send a message via MSN to Paralyzer
this has been discussed many times in probably 10 or more threads...if you dont touch tire size or gear ratio it will stay factory, but if you change one or even just LOOK at it you MUST change both.
edit just noticed this thread is very old :O
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
