Thanks very much, you've helped a lot of people with that information, excellent!
Have fun, & keep in touch,
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
Online Superchip ordering system:http://www.f150online.com/scpp/index.html
Very Cool,
I checked out the digital dash last night, it was fun to play around with. The only thing I didn't see was something that said fuel, I have to find out what the rest of the terms mean. Thanks Neal
HI!... GINOSF-150 : There is one for fuel. It says FUEL. It tells you how many gallons you have left in your tank. It kinda helps out when your low fuel light comes on and you start to get worried if you'll make it to the next gas station.8-)
NEAL [ the horsepower freak ] NEWMAN
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, **** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, AUTOMETER guage pod and tranny temp guage, custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP.
FUTURE MODS : JBA headers, power pulleys, twin electric fans, traction bars, BAUMANN ENGINEERING shift kit, POWERAID, and a KENNE BELL BLOWZILLA supercharger.
ESTIMATED H.P TO DATE : 310H.P / 405ft/lbs of torque.
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w 530H.P(natural), 750H.P with N.O.S, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
The fuel one isn't telling you how much fuel you have left... how do I know? because this morning with my gas light on, the gauge was fluttering between 79-80 while the truck was idling... I think it may be a fuel pressure gauge or an air/fuel mixture gauge. When I'm driving and step on it, the number drops down to the high 40's for a bit, but usually returns to the 80ish mark.
------------------ Silver 99 F150 XLT 4.6l 4x2 Sport Extended Cab with Flare Sides... Mods: K&N Air Filter, Tinted Side Windows, Flowmaster 40 Series Catback System, Reese Class 3, Airbox Mod's, Fiberglass Tonneau Cover, B&M Tranny Cooler, Tranny Temp Gauge, Water Temp Gauge, Autometer A-Arm 2 Gauge Pod Kit, Auburn Limited Slip Differential, Ford Bug Deflector, Alpine Deck, 6 Disk Changer & Subwoofer Processor, Zapco AG750 Amp (times 2), Zapco AG360 Amp, JL 10W3 (times 4), JL Audio VR Series 5.25" Component Speakers (times 4), JL Audio VR Series Tweets (times 2), & 1 Farad Cap (times 2) Coming soon: Spray-On Bed Liner, B&M Electronic Shift Improver, Headers(?) Coming this Spring: Kenne Bell Supercharger, BellTech 2"/4" Drop Kit, New Wheels & Rubber
This is sweet stuff. I'm about to go try out ya'll little trick with the dash. I have a 99 XL sport, and I was wondering if ya'll knew if its possible to do a cluser swap with a cluster that has the tach on it and if it would work with out any extra wires?
1999 Ford F150 XL Sport
4.2L Flarside
Anyone know how to keep the tach on so it doesn't shut off when you shut the truck off? I would much rather see the tach than the odometer! Also, by looking in my service manual, it looks as if the white/pink wire that runs into the instrument cluster runs the tach. I tried hooking an aftermarket tach up to this wire, but it didn't work? Any ideas?
I've been playing with the fuel section, and following the webpage from mustangworld. If anyone is interested in keeping more accurate track of the mileage: the last time I filled up the tank, I took readings every time I put a gallon in. Because the tank isn't a perfect cylinder or box, the rate at which the level rises or falls depends on the level of the tank. The biggest changes happened around full where it's something like 10-12 numbers per gallon. Near empty (1/4 tank) it's more like 4-7 numbers per gallon. Well that's enough engineering for now.
'99 Lariat Supercab 4x4 SS
5.4L, 3.73 Diff (9.75" LSD Rear, 8.8" Front) ORP: Skid Plates, LT265/70R17 GY Wrang. AT/S Group III towing: HD Electrical/Cooling, GVWR 6500# (Extra leaf spring).
Step Bars
4W Disc anti-lock brakes
K&N filter Stock Items That Differ Across F150s: Steel Driveshaft, Oil filter bolted to engine w/ drip guard, 4R70W transmission.
GSXR: I don't think it's gas sloshing around, because it doesn't matter if I have a full tank of gas or the gas light is on, if I sit in my driveway it's always in that range.
cd
FUTURE MODS : JBA headers, ASP power pulleys, twin electric fans, traction bars, BAUMANN ENGINEERING shift kit, POWERAID spacer, AUTO METER oil preasure/ engine temp PHANTOM GUAGES and a KENNE BELL BLOWZILLA supercharger.
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Ryan
Thanks to SFX.net 1999 F-150 XLT SCAB 4x4 Mods:BBK Shorty Headers, 33" Yokohama Geolandar MT+, Airaid CAI, Cherry Bomb Glasspack, AVS Bugflector II, Tailgate LED light bar, Sony XPLOD Bluetooth HU, Pioneer Speakers, MTX Thunder Subwoofers, Sony 1100W Amp, ETC. Soon To Come: RCX 5" Suspension Lift, And Lots More. Check Out My Progress Thread: Progress Thread 99' F150 Ram This FORD Dodge Boy!
