2016 White Platinum Tricoat....bad stone chip on hood
Hi, just bought a 2016 with white platinum tricoat and first highway trip up north i get a big rock chip on drivers side of hood. It appears to be a tan color....so this is right down to base primer or metal? Of course my eyes are drawn to it like laser beams now. What is the best way to touch this up? Is the motorcraft tricoat platinum white kit enough?...or are some aftermarket kits better?
Thx & Rgds,
Andy
Thx & Rgds,
Andy
No matter what method you use to fill in a chip like that, it's going to show to some extent. Given that you say there's a tan color showing, I don't think you're down to the primer - which is good. I might suggest the Dr. Colorchip system. I don't know if they make it for the color you have, but I've had some success with it on my silver car and white truck.
In re-reading your post, you may be talking about the spray stuff that you can apply yourself. I tried it and don't think much about it. In my opinion it was hard to control the thickness during application and it did not hold up well. You, of course may have better results.
I'd recommend you seriously consider a professionally applied film. It is almost impervious to rock chips and is almost invisible when applied. But, of course, it is not cheap.
Before you do either one, spend a little time on the chip you had repaired to get the repair perfectly flush with the surrounding surface. If you do it right, the repair will be almost invisible and any kind of paint protection you put over it will work better.
- Jack
The Ford Motorcraft touch up is a two in one applicator with base and top coat, pen and brush. It's not perfect but it's mostly hidden now. I went ahead and had Ford do a layer of 24" wide film on leading edge of hood and front quarter panels, so hopefully that will help out.
- Jack
