roof rust repair
Old 07-14-2014, 07:39 PM
F150man21's Avatar
roof rust repair
2000 scab
so i noticed some little rust spots on the roof of my truck today. i was gonna just sand it down and paint over it with some rustolium, but what do y'all think?
thanks
Old 07-20-2014, 01:41 AM
czarboom's Avatar
no, you want to sand it down, but use a color match pen and some clear coat. If that does not do it, then the sections needs to be redone. Sometimes clean finger nail polish can work but only for small spots
Old 07-20-2014, 02:12 PM
F150man21's Avatar
well its on my roof so i dont care about the color. so i should just sand it down and put some clear coat on top?
thanks
Old 07-22-2014, 11:54 PM
czarboom's Avatar
you can, as long as you make sure the new clear coat blends into the old, meaning if you leave a gap then it can peel up.
Sand and clean carefully with some rubbing alcohol then dry and apply clear coat. it should work, I say should because weather etc can do all types of weird stuff
hope that helps
cz
Old 07-29-2014, 07:02 PM
thzpcs's Avatar
How big are the spots? If you really don't care a bunch of what it looks like, I'd say spray some rust converter on there, even it out with some sanding, then do a coat of Plasti-Dip
Old 08-23-2014, 03:52 PM
F150man21's Avatar
thanks for the replies. the rust spots are tiny, about the size of a bb.
Old 08-23-2014, 04:56 PM
Swamp Daddy's Avatar
You'll definitely want to sand to get rid of the rust spots. If you just cover up the rust it will keep eating away at the metal of your truck.
Quick Reply: roof rust repair
