F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Care & Detailing
Thread Tools Display Modes
Old 08-02-2009, 11:51 AM
Vehicle: 2009 Ford F150
Preventive Maintenance - Wheels
I just bought a 2009 FX4 and I want to do some preventive maintance to the wheels, mostly to keep brake dust from becoming an issue. Should I just wash and wax or is there something better I can do?
This is my first brand new vehicle! Everthing else I have owned came with a nice thick coating of brake dust!
Steve
Old 08-02-2009, 11:56 AM
Vehicle: 2005 Ford F150
The best solution for brake dust is to get those sorry pads off. Replace them with Wagner ThermoQuiets and you will forget about brake dust. I did mine when my truck was nearly new. I have 80,000 on the pads now and never see any brake dust, just your normal road dirt.
Flowmaster 40, K&N dropin, Tint, Roush wheels, 305/50/20s
Edge Evo with PHP custom tunes, GF 2" shackles
Old 08-02-2009, 12:48 PM
glc glc is offline
Vehicle: 2003 Ford F150
Ceramic brake pads.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 08-04-2009, 08:09 AM
Vehicle: 2003 ford f150
wheel wax
Old 08-04-2009, 01:22 PM
Vehicle: 2006 Ford F150
Don't use the brakes.
2006 F150 FX4
Luxury Package
20" Rims
3.73 Limited Slip Axle
Audiophile 6 CD Sound System
Heated Leather Trim chairs
XM Radio
Old 08-04-2009, 04:12 PM
Vehicle: 1993 Ford F150
Meg's Quik Wheel Detailer. Use it every other day, or as often as needed. You can use it anywhere and all you need is a towel for wiping. Waxing the rims will work till it gets burned off. It's much easier to just stay on top of it with QWD.
Old 08-04-2009, 04:45 PM
Vehicle: 2004 Ford F150
Send a message via AIM to TruckGuy24
Quote:
John
Thanks Watson91 at S-FX
PTM Century Tonneau
Remote Start
14" si/do Magnaflow 45'd behind rear tires
4" x 18" SS Tips
Roush Grille
Billet Bumper Grille
PTM Mirror caps
DVW Intake w/ K&N drop in
Quote:
Originally Posted by 05RedFX4 View Post
Best of luck to you, and hopefully you don't have the same attitude when you go into the dealer to get your trans fixed, because if you do your gonna need a big jar of vaseline cause they are gonna stick it to you, HARD
Old 08-04-2009, 08:34 PM
Vehicle: 2005 Ford F-150 4x4
OK, so how about some really useful advice. First, congratulations on your new truck. As you've probably already noticed, the factory pads are capable of generating quite a bit of (abrasive) dust, so until you replace them, you're going to have a nasty and possibly destructive mess on your wheels. When you want to remove the dust, resist the urge to just "wipe it off." You'll just scratch your wheels. Make sure to use a good automotive detergent and lots of water.
Second, heat is the enemy of conventional Carnauba waxes, so using anything like this to protect your wheels won't last long. Most of us with experience recommend a synthetic sealant instead such as Zaino, Meguiar's NXT, Mothers Synwax, etc. Even these will only last a few weeks at best.
My recommendation? Go with the Wagner Thermoquiets. I have them all the way around and am very happy. Next, wash the wheels regularly as mentioned above and apply freash sealant every couple of weeks. Good luck!
2010 F-150 4x4 XLT Regular Cab Short Box
Lights Behind the Grill Gallery:http://www.f150online.com/forums/mem...ind-grill.html
Interceptor Light Bar Gallery: http://www.f150online.com/forums/mem...light-bar.html
Old 08-04-2009, 10:17 PM
Vehicle: 2007 FORD F-150 5.4L
Not much you can do, ime. Brake dust will inevitably build up, especially on the fronts. I use Meguiar's Ultimate Quik Wax after I complete the detail process for my vehicles. Very easy on and very easy off- it provides slickness and a great shine.
Old 08-07-2009, 02:09 PM
Ok here is what I did ,
First I got Metallic Pads all the way around
Second I sprayed the inside of each rim with degreaser and then scrubed them out real good and dried them off.
Third I sprayed the inside of my rims with about 4 good coats of high heat clear coat,, Now any brake dust I get just washes right off.. I dont know how long this will last but it's been going strong for 6 months now
John B
2003 FX4 5.4L K&N Cold Air, and Other Stuff
Owner of
B&R Fire Protection
Old 08-08-2009, 11:28 PM
Vehicle: 2004 FORD F150
I took the route that "2strked" suggested....
I use ZAINO on my wheels, which is a POLYMER, and it provides very good results even though I'm still using MOTORCRAFT pads
I would suggest ZAINO for the entire car.....
http://www.zainostore.com/
Old 08-09-2009, 12:24 PM
glc glc is offline
Not the best choice to avoid dust - ceramics are a LOT cleaner.
Old 08-15-2009, 10:29 AM
Thanks for the advice guys, while looking into the Wagner ThermoQuiet brakes I found a rebate.
http://www.tqbestforless.com/
Steve
Old 08-25-2009, 01:50 AM
Vehicle: 2007 FORD F150
Thumbs up
+2 on the Ceramics. They are much cleaner.
Old 08-26-2009, 06:16 PM
Vehicle: 2005 F150
I've tried Wagner and Porterfield pads and have the polar opposite of everyone else's results. After 50 miles of driving there is dust on the front wheels. Not as much as the OEM pads, but enough you can see it. This is both with the OEM rotors and powerslots. I'm not trying to stir a pot here, but I think the dust is inevitable no matter the pad, just like sanding wood yields sawdust.
Our Mustang is completely opposite, the rears dust up much worse than the fronts.
I usually use NXT on the wheels every few weeks, mostly just to get rid of it. It does help wash it away.
If a hammer won't fix it you got an electrical problem.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
