bug coated radiator
Old 07-17-2009, 11:37 PM
LightningSuperD's Avatar
bug coated radiator
any suggestions on cleaning bugs off a radiator. Anybody think that a wire brush will hurt anything?
Old 07-18-2009, 12:16 AM
jetech00001's Avatar
wire brush i would think it would cause you a world of trouble i have always used a garden house or a high pressure washer i spray back to front. be careful of the fins or you will roll them
Old 07-18-2009, 09:56 AM
Makina's Avatar
I would stick with a brass wire brush, and do it by hand if you're going that route.
But first I would pretreat with a bug wash and use some high pressure water i.e. at a car wash. You'll get most of them out that way.
Old 07-18-2009, 11:05 AM
Micheal's Avatar
Just use a tire cleaner brush from your local wally world. These have stiff plastic brissels. Dont use any brush with metal brissels. Just my opinion.
Old 07-18-2009, 12:00 PM
jdruzik's Avatar
I use a stiff bristle 1" round brush and hand clean. I don't use any water. The bugs will come off easier if it's dry. My brush was purchased at a local auto parts store.
This is a nylon brush and it will not damage the fins...
Old 07-18-2009, 02:29 PM
imo using a a very stiff bristle brush will damage the fins i would pretreat with with a soap and use a garden hose or high press washer and be real careful of the fins if you roll some they make a tool to straighten them out hope it works out for you.
Old 07-18-2009, 11:31 PM
thanks for all the info. I did not know that water sprayed from behind would go through to front.
I will try to clean by hand first when it is dry. Then loosen up with some warm soapy water and continue to clean. Finally, if there are any more lil buggers I will work (gently) with a brush with plastic bristles.
Old 07-19-2009, 08:41 AM
clambelly's Avatar
avoid the problem altogether by installing a redneck bug screen in front of your radiator. Get some aluminum screen from home dope and install just in front the rad, use metal tie wire; DO NOT USE PLASTIC SCREEN OR PLASTIC TIES
Old 07-19-2009, 12:39 PM
NASSTY's Avatar
This was one of the first mods I did to my truck when I bought my truck new about 3.5 years ago.I bought a bug screen at Walmart for about $4 cut it to fit and put it in front of my a/c condensor.My condensor has never been exposed to bugs.
Old 07-19-2009, 01:48 PM
NASSTY great idea i am going to get some and do it to all my cars
Old 07-20-2009, 05:02 PM
that is a great idea. how did you attach it?
Old 07-21-2009, 06:19 PM
NASSTY's Avatar
Small wire ties
Quick Reply: bug coated radiator
