F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Care & Detailing
Thread Tools Display Modes
Old 07-03-2009, 02:00 PM
Vehicle: 2006 Ford F150 XLT
Hardcore water spot removal?
Anyone know a sure fire way to remove those nasty looking water spots off of the windows and off of a few body panels?
2006 Ford F150 XLT - 281ci V8 - Regular Cab/Flareside - 2WD
True Dual Magnapack Exhaust - Gott's CAI - Edge Evolution Programmer
Mustang Exhaust Exhaust Interior Drive By
Old 07-03-2009, 02:18 PM
Vehicle: 2001 Ford F150
clay bar ftw!
2001 F150 Single Cab Flareside M5OD
thanks to DirtyD @ www.screen-fx.net
CHECK OUT MY ALBUM!!
Old 07-03-2009, 02:22 PM
esf esf is online now
Vehicle: 2002 Ford Expedition
It depends on how bad they are. It also depends on what tools you have at your disposal or are willing to buy. Getting them out by hand can be a chore. RR has tried a few things and even had to resort to wet sanding to remove them. Not all of them are going to require that extreme of a step. How have you tried tog et rid of them thus far. Meg's 04 works wonders on windows via a rotary buffer.
Mods
BBK 75mm Throttle Body, AFe Stage II CAI, Granatelli MAF, OBX Long Tube Headers, Magnaflow High Flow Catalytic Converters (#94306), Magnaflow 3" Catback (#15681), Troyer E-Fans, ASP Pulleys, SCT X3 with Custom Troyer Tunes, Pro Comp 1069 18x9 w/ Cooper Zeon LTZs 285/60r18
Old 07-03-2009, 03:16 PM
Technically, I have a homemade rotary buffer, foam pad with a microfiber cloth covering it, mounted on a cordless drill. I tried Scratch X for the paint and it seemed to make the major ones go.
I've also tried clay barring them, but the bar just doesn't even dent them.
Old 07-03-2009, 03:39 PM
They're probably etched in to the clear. That's why the SX removed some while the clay did nothing. They do make special products for removing water spots. I believe CG has one called Heavy Duty Water Spot Remover. I think this is one of the products that RR used. I don't remember the results but since he ended up wet sanding, I want to say it wasn't enough. Steve (Poorboy's World owner) I believe recommends his Professional Polish. This is something that could take trial and error before you find out just how bad they are and what is needed to fix them. I'm going to pretend like I didn't hear about your home made buffer. It kind of scares me. However, you might want to try using a terry cloth bonnet since it will provide more cut than microfiber. You may end up needing to compound them out which would also require a lighter polish to follow it up.
Mods
Old 07-03-2009, 04:13 PM
lol, yeah the franken-buffer took me 5 minutes to make and actually takes longer to use than by hand, and the batteries keep running out.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
