What are you Guys using for Tire Blackener
Old 05-24-2009, 11:18 PM
I'm crazy about this, constantly doing it, really working it in. I've experimented with a few and the best so far I've used is Armour All Extreme Gel. What have you guys tried with success?
Old 05-24-2009, 11:31 PM
I like Megs Hot Shine Spray. Spray it on, wipe it off.
johnnyd2723's Avatar
Have you tried Megs Hyper Dressing? Good stuff You can mix it at different dilutions to get a matt shine or a satin look, mixes w/water. Plus you can dress your frame, fender wells, etc. Check it out: http://www.autodetailingsolutions.net/d17032.html
Old 05-25-2009, 12:48 AM
wasachevyguy's Avatar
I put on a coat of Meg's Endurance tire gel, let it dry, and then hit it again with another coat.
Old 05-25-2009, 11:52 AM
toolmaann's Avatar
Stoners... "More Shine"
Old 05-25-2009, 01:09 PM
ELVATO's Avatar
Meg's Hot Shine Foam. Although HD is a close second, since you can use it on your tires as well as pretty much any plastic.
Old 05-26-2009, 12:59 AM
RollingRock's Avatar
Like many of you, I went years of trying different products until I found HyperDressing. It's by far the best that I have used. It's very versatile.
2 thumbs up.
RR
Old 05-26-2009, 05:45 AM
Ok thanks guys... I may have to check that out... where is the best place to get it, or is it available online only?
Old 05-26-2009, 02:12 PM
Probably easiest to get from ADS
Old 05-26-2009, 02:53 PM
glc is offline
If you want a glossy wet look, Megs Hot Shine gel is as good as any - use a Eagle One or equivalent tire swipe. It *will* sling, and it *will* turn brown.
Old 05-27-2009, 08:28 AM
SSCULLY's Avatar
I use the PB tire dressing. Works well.
This is the natural look version that I am talking about, so I don't know if that will work with what you are looking for.
Old 05-27-2009, 08:54 AM
cheesepuff1's Avatar
what is the eagle one or tire swipe? does this keep them from turing brown? i use megs hot shine in the adjustable spray pattern..
Old 05-27-2009, 09:06 AM
PB does make a Trim Restorer, it is very good but I would argue that BW is better for this purpose. PB TR can be used to manitine what you fix as well as Hyperdressing. PB NLD isn't going to going to restore however, it works great and is a favorite of many here for interior work
Old 05-27-2009, 02:38 PM
GB Black Lariat's Avatar
Im all about Meguiars.. thats all I use but..... for tire gloss I use Eagle One Gel. Lasts longer than Meguiars and doesnt sling at all.
Old 05-27-2009, 03:02 PM
rabbit hunter's Avatar
No, it dont keep from turning brown. It is just a applicator to apply tire shine.
This is a Eagle One tire swipe
Quick Reply: What are you Guys using for Tire Blackener
