03-28-2009, 04:43 PM
Clay Kit
Is the Turtle Wax Clay Kit any good? I saw it at Wal-Mart and bought it.
10 Lariat SCREW 4x4
2" front Leveling kit
Edge EVO CS programmer
MagnaFlow exhaust
33" Toyo Open Country A/T2 tires
Randall
03-28-2009, 10:29 PM
The liquid clay? Nope.
2003 F-150 XL RCSB 2wd 4.2 M5OD 3.55 LS
03-29-2009, 10:14 AM
2007 Ford F-150
Vehicle: 2007 FORD F-150 5.4L
I would avoid those kits with the tiny bars all together and just get the original Clay Magic bar only, #CM2100. 100 gram for $11.44. Unless you're detailing for a living, buy a couple, you'll be set for quite awhile. Buy a bottle of ONR, mix 2 oz. to a gallon of water, and you have a whole lot of clay lube.
http://magicgarage.biz/dnn/Default.aspx?tabid=70
03-29-2009, 10:52 AM
The Megs and Mothers clay kits are fine. Clay Magic holds the patent on clay bars anyway, it's the same stuff. Good point on the ONR, that would be the only thing I would use as a lube other than a QD spray.
If you buy a 100 gram bar, you will want to tear it apart anyway.
03-29-2009, 11:19 AM
2007 Ford F-150
The reason I would say to avoid those "kits" is because they are not cost effective at all. Especially when you consider the size of our trucks. If you add the possibility of doing other family members vehicles, etc. its a no-brainer, ime.
03-29-2009, 12:26 PM
2004 Ford F-150
Vehicle: 2004 Ford F150 4X4
Quote:
Originally Posted by carlsson3
buy a bottle of onr, mix 2 oz. To a gallon of water, and you have a whole lot of clay lube.
onr?
Wake up, Neo... The Matrix has you...
Superchips,Injen,Corsa,Bilstein5100s
03-29-2009, 12:36 PM
Garage is empty, add now
Vehicle: 2002 Ford Expedition
Optimum No Rinse... great product You can dilute it for rinseless washing, clay lube or quick detailer depending on ratio.
Mods
BBK 75mm Throttle Body, AFe Stage II CAI, Granatelli MAF, OBX Long Tube Headers, Magnaflow High Flow Catalytic Converters (#94306), Magnaflow 3" Catback (#15681), Troyer E-Fans, ASP Pulleys, SCT X3 with Custom Troyer Tunes, Pro Comp 1069 18x9 w/ Cooper Zeon LTZs 285/60r18
03-29-2009, 02:07 PM
2004 Ford F-150
Quote:
You are talking about Optimum No Rinse Wash from Optimum Polymer Technologies?
03-29-2009, 02:57 PM
Correct
Mods
03-29-2009, 03:10 PM
2004 Ford F-150
Correct
Damit man! I should have know that.
After many years of Navy life you would think I would be good at acronyms and knots and I suck at both most days.
03-29-2009, 03:37 PM
It's alright. Buy each of us a gallon and I think we can let it slide.
Mods
03-29-2009, 03:42 PM
2004 Ford F-150
I will set it up to arrive in the mail in 5 weeks on April 31st. That's the best I can do.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
