Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Care & Detailing
Thread Tools Display Modes
Old 08-24-2008, 09:35 PM
Vehicle: 2005 ford F-150
Question Window Squeals
My drivers window squeals (like glass on rubber) when rolled up or down. Any products that I can apply to stop this? I've tried silicone, rainx, etc... No Luck!
Seems like the rubber has dried out. Any advice? (my windows have custom tint on inside).
Old 08-24-2008, 09:44 PM
Vehicle: 2000 Ford F150
mine get like that after i wash and put rainx on them. but goes away after a few times. i dont get it either haha
Old 08-25-2008, 03:47 AM
Vehicle: 1986 Ford F150
Usually that squeal is from tint glue or something sticky on the window. My Mustang did that, and when they cleaned the front windows before they tinted them, there was some old tint glue on the window still.
Did it do it before it was tinted as well, or just after?
1986 Ford F150 XL 4x4
5.8L 351W 4BBL H.O. V8
2002 Roush Mustang Stage 2 #6347
4.6L SOHC V8
Old 08-25-2008, 12:53 PM
Vehicle: 2004 Ford F-150
I posted in your other thread already, but like I said, 1 window at a time squeaks, two windows doesn't, so maybe try two to ignore it.
2004 Ford F-150 XLT Supercab 5.4L 4x4
Appearance: Gloss Black Grills/valance/wiper cowl, 20% Tint, LED Reverse & Plate Lights
Performance: 2.5" True Duals X piped, Rear Cats Deleted, Magnaflow 11" Bodies, Magnaflow 4x18 Rolled Tips.
Suspension: Bilstein 5100 Leveling Struts & Rear Shocks.
Videos: Start Up, Revs, Driving. Fly-By Sounds Burn Out Video Interior Sound/Drone
Old 08-25-2008, 10:32 PM
no it just started,drivers window only kinda weird.I think it might have something to do with the spot free rinse at the carwash......yep I can be that lazy...maybe its just payback. Thanks for the reply.
Old 08-26-2008, 02:38 AM
Seems like you've used a bunch of stuff that adds more junk to the window surface. Have you tried wiping it a couple of times (on the outside only) with something like rubbing alcohol to remove anything on the surface that may be causing it to squeal?
4.6L SOHC V8
Old 08-26-2008, 03:18 AM
Vehicle: 2006 Ford F150 4x4
My driver side window does this as well. I havent tried anything yet to try and stop it, and i do not have any tint on my front windows.
Old 08-26-2008, 04:05 AM
Its probably when the windows get dirty on the exterior, it builds up as it slides up & down and dries the seals out. Goes along with roushstage2's theory.
Old 08-27-2008, 12:49 AM
Just throwing this out there: When I first had that happening on my Mustang and I took it to Ford, they told me to spray WD-40 inside the window to lube the tracks. It did nothing but make an oily mess on the window every time I rolled it up or down and it took many, many window cleanings for it to stop. If they suggest this (if you take it in), tell them to remove the door panel and spray the tracks, not the window.
4.6L SOHC V8
Old 08-28-2008, 01:55 PM
Vehicle: 2005 ford f150 fx4
Try CRC heavy duty silicone, marine grade. Lower window, apply in the tracks only. No oily mess. This is also the fix when the window doesn't want to close or closes slowly.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150online is not affiliated with the Ford Motor Company.
