foam for application. terry for removal, if you must (I prefer removal by hand). throw the lambskin away, don't use it on your paint. (way too course, and will create swirls/marring)
you will get no corrective abilities from a random orbital, but it will save your arms for applying and removing wax.
I would not recommend using the machine to remove a carnuba based wax, as the terry bonnet can "load up" and cause some micro marring, but you could use it to remove a synthetic, if you wanted to, with minimal risk.
I have assummed that your random is a 8" to 10" "waxmaster" type. if not, then ignore everything I have said other than never using the lambskin bonnet.
