F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Care & Detailing
Thread Tools Display Modes
Old 04-07-2008, 09:42 PM
Vehicle: 03 4X4 5.4 SCREW
glc, outstanding job and great post
Old 04-08-2008, 02:44 AM
glc glc is offline
Vehicle: 2003 Ford F150
I think I'm gonna go over to Harbor Freight tomorrow and get my own cordless drill - they have a kit with a 18 volt drill 0-900 rpm, a flashlight, one battery, and a charger for 20 bucks, a second battery is another 10 bucks. I'm sure it's a cheap piece of crap but you can't beat the price. Should do what I need, I don't need contractor grade tools. I'm toying with the idea of starting a mobile service at a lower price than the body shop, I think I can do a better job from what I saw of their work.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 04-08-2008, 02:58 AM
Vehicle: 2006 Ford F150
Send a message via Yahoo to attworth
For condensation, I usually take the head lights out and set them under a low heat lamp (like from a terrarium, etc.) The ability of the gaseous H20 to be able to escape via the bulb socket is great. I then run a bead of clear or black silicon around the lens seal to make sure it stays dry. I've done a few of my friend's lights and they've been extremely impressed. For the little amount of time it takes, it's well worth it to some people.
As RP was saying, I find Plast-x to have just enough cut to get rid of the marring induced by the wool and #85.
Old 04-08-2008, 03:30 AM
Vehicle: 2004 Ford F150
i used the dryer with the rack for my fog lights dryed them right up then some shoe goo to seal em works great no water
Old 04-08-2008, 03:44 AM
Awesome read, great view.
Kudos.
Old 06-22-2008, 02:13 AM
glc glc is offline
Quote:
Originally Posted by BlueFlareside View Post
Was the vehicle wrecked at one time? I noticed that the Dodge emblem is not in the middle of the hood.
http://bbscomp.com/george/100_0102.JPG
I found out that this is how the van was delivered, brand new.
Old 06-22-2008, 03:50 PM
Vehicle: 2003 Ford F-150
Send a message via AIM to andrewc_11890
Wow that looks amazing.
I tried out using just straight up Plast-X on my girlfriends dad's van. I knew he had some pretty faded headlights, so I wanted to see how well just Plast-X would work (this was a test to see if I should get the wetsanding method from ADS)
Unfortunately I didn't take any pictures
It did surprisingly better than i had expected. They were yellow, but are now no longer yellow. They still had a bit of haze in them. I would say it was about 1/4 of the haze that your lights looked like after wetsanding, but was nowhere close to the completely clear headlight that you got.
Thanks for the review, I definitely think that Rick's kit will be worth the money if someone wants a full headlight restore, but if you don't care too much I think Plast-X alone can do a pretty decent job.
Old 06-23-2008, 01:17 AM
glc glc is offline
You should be able to pay for the kit with one or two restoration jobs. The only things you need that are not provided are a bucket of soapy water, masking tape, and a drill.
Old 11-22-2008, 07:14 AM
Vehicle: 2001 ford 250
great ideas guys.. my crown vic lights are faded big time and have condensation. i was gonna pick up some new ones on ebay but...much better ideas here.
Old 11-22-2008, 02:01 PM
Vehicle: 2004 Ford F-150
Send a message via AIM to DarrenWS6 Send a message via Yahoo to DarrenWS6
Lights look great as brand new again, great job!
2004 Ford F-150 XLT Supercab 5.4L 4x4
Appearance: Painted Headlamps/Fog lamps, 20% Tint
Performance: PHP Gryphon 87 Perf, 2.5" True Duals X piped, Rear Cats Deleted, Magnaflow 11" Bodies, Magnaflow 4x18 Rolled Tips.
Suspension: Bilstein 5100 Leveling Struts & Rear Shocks, 20x9 XD Monsters, 33x12.5 Toyo M/Ts
Videos: Start Up, Revs, Driving. Fly-By Sounds Burn Out Video Interior Sound/Drone Tunnel Carwash Rev
Old 11-22-2008, 03:42 PM
Vehicle: 1997 Ford F150
The lights do look great. I have several cars that have had the lights polished. It makes the car look much better. I believe as the plastic ages the UV stablizers disappear. Even after polishing, the lights dull back much quicker than new lights. A light polish/wax every few months keeps them looking good.
For best durability, the lights should be wet sanded with 1000 grit and clear coated with a catalized automotive clear coat. I did my '91 Mustang almost 3 years ago with no wax or polish. After 3 years outdoors, the lights still appear new. I'd think if you sanded and masked them you could find a body shop to do them cheaply. They could use a little of the clear at the bottom of the cup that would normally go into the paint waste. It would probably take less than an ounce to do 2 coats on both headlights.
97 XLT S/C Long Bed 2wd, 4.6 Romeo, 4R70W trans, 325,000 miles
Old 11-22-2008, 10:12 PM
I second the use of a dryer.
To remove the condensation, remove the light bulb from the housing (with the housing still installed on the van). Then take a hair dryer and blow hot air into the hole until all the water evaporates. This should not take long once you get it to temperature.
Old 01-16-2009, 11:35 PM
glc glc is offline
A bump to the top.
The new site (www.autodetailingsolutions.net) does not have the #2 kit any more - just the PlastX kit that Meguiars packages themselves at the factory. I'm disappointed.
To put one together yourself, you will need the following:
1500 grit wet/dry sandpaper with flexible sanding block
M85 Diamond Cut
PlastX
Small wool buffing pad for drill
Small foam buffing pad for drill
Detailing brush for cleaning pads
Maybe Rick will still put them together on request - probably need to call or e-mail him.
Old 02-26-2009, 07:56 PM
Vehicle: 1998 Ford F150
Send a message via AIM to D's984x4
Is there any other kit out there for restoring very badly faded headlights? I looked at the Meguiars kit but don't want to get all the extras. Is there any other kit that has everything included? I looked at some websites but 1. I couldn't find what I was looking for, and 2. I don't know exactly what I am looking for lol. Any help is appreciated. Thanks!
Old 02-26-2009, 08:04 PM
esf esf is offline
Vehicle: 2002 Ford Expedition
What kit did you look at? The actual Meguiars kit contains only 3 things. PlastiX, Drill mounted pad, and an mf towel. Now the other kit that ADS offers will dork great and $40 is a lot cheaper than new headlights.
Regardless, here they both are... http://www.autodetailingsolutions.ne...storation.html
Mods
BBK 75mm Throttle Body, AFe Stage II CAI, Granatelli MAF, OBX Long Tube Headers, Magnaflow High Flow Catalytic Converters (#94306), Magnaflow 3" Catback (#15681), Troyer E-Fans, ASP Pulleys, SCT X3 with Custom Troyer Tunes, Pro Comp 1069 18x9 w/ Cooper Zeon LTZs 285/60r18
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
