Whats a good polish to use before waxing?
on
1 Post
Translation...
Use MaGuire's #9 product, with a yellow application pad (part of accessory kit for -> ), Porter Cable buffer, set on #4 speed?
I think that might be it.
But seriously, asking this question is like asking what is the best Cabernet...everyone has their own opinion.
I currently use: Clay bar...MaGuire's NXT, followed by their #26 carnubia wax.
Rockpick, however, is the God of detailing...do a search on this topic and you'll be reading for days.
Originally posted by BlueOvalFitter
Both,on the swirl marks.Its been almost a year since ive polished it.About 2 months since ive washed it.Does that help?
First, it sounds like you want to pick the products up locally. That being the case, the product that poolvibe point out............ the Meguiars #9 Swirl Mark Remover might be a good place to start. It sounds like you don't have a PC (Porter Cable buffer), so you'll be doing the polishing by hand. Therefore, the #9 is about as abrasive as you can get by hand with decent results.
The 3M Finish Restorer is an all-in-one product. (cleans/polishes/protects). It's actually pretty decent stuff. However, it won't do much for the swirls, but it will clean the paint nicely. It is also a bit "finicky" to work with. If you want to try a good all-in-one product that can be found locally, I would suggest Meguiar's ColorX.
Hope this helps.
BossMan,thank you for the info! Ive seen the Color X at Wal-Mart.One more question; Can you recommend a good wax to follow up with?
First, you're welcome!
Keep in mind, that the ColorX will not remove/hide swirls like the #9.
As for the wax.............. sure, for a wax that you can pick up locally, Meguiar's NXT, or #26 (or #26 over the NXT) would look great.
Have fun.
http://www.mark-v.com/index.html
They are local here where I live
I use the seal bright, true blue dressing, and thier klenzol a lot...
detaildirect sells some of thier stuff...
http://www.detaildirect.com/cgi-bin/dd/index.html
