Bedliners, Caps, Tops & Lids
Bed cover that is toolbox compatible
Old 10-10-2016, 10:35 PM
Taylor Hesketh's Avatar
Hey guys I have a Ford F-150 with a standard bed and I bought an Access Toolbox edition tonneau cover and I have a Weatherguard toolbox that has lock/unlock keyholes on the front of the toolbox. Unfortunately when I went to install the bed cover I realized that the L channel that is supposed to drain water away is at the same level as the toolbox locks and I wouldn't be able to use my toolbox anymore if I installed the cover. Do y'all know of any soft rollup covers that are compatible with toolboxes that have locks in the front instead of the sides?
Old 10-11-2016, 09:18 AM
I'd think you'd need to get a box that has keys locks on the sides
Old 10-15-2016, 10:11 AM
jgger's Avatar
Remount the tool box with a 2x4 between the bed rail and the box mount, this will give you 1 1/2" of lift and may raise the locks high enough to clear the drain channel. It also helps as a vibration damper related to other bed mounted box issues.
Old 02-12-2017, 07:01 PM
scadams's Avatar
Extang
Extang makes a tool box bedcover.i had one on my 2011 worked great!
Quick Reply: Bed cover that is toolbox compatible
