HELP!! My bed is destroyed! Need ideas!!
Please help. I just bought a 2000 Ford 150XLT the price was to irresistible to pass up. Unfortunately the bed is destroyed. The side panels are barely connected. I feel that the only thing holding up the side panels is the liner in the bed. I'm not sure what to do. I need any and all ideas please. The beams holding it up in the back are all rusted out. I can put pictures up if need be.
My '77 had some rust and I saw some other like vintage trucks with floppy bed sides back in the late '80s already, so before mine had floppy bed sides, I covered the floor with some 11 gage steel plate all over (used one sheet) and double plated the front wall, then I ran a 4" wide 1/4" thick steel strap across rear of bed behind tailgate hinge area and then used some 3/16" thick 1-1/4" x 1-1/4" angle notched and gusseted to go up from that long side to side piece and tied in to rear standard boxed corners and removed tail lights to get access for nuts and big washers .... put tail lights back in.
To this day, you can drop the tail gate and try to shake the bed sides and all you shake is the whole truck, the bed sides are solid.
As near new as it is, I'ld look at a complete used bed to start with and mod that for long term.
