Best DIY Roll on Bedliner?
If Raptor works for you, then great. It's good to have choices.
This is just for fun:
If you look at U-pol Raptor's MSDS, you will see that it contains 683 grams/liter of solids (which is about 68%). That means that 317 grams/liter is solvents that evaporate away (which is about 32%). So, for every gallon of Raptor you buy, you only get about 3/4 of a gallon of actual "bedliner". So, using a useful formula that I have and assuming you have a short bed truck (6.5 ft) which has about 78 sqft to spray with the bedliner, then one gallon of Raptor will give you about a 15 mil thickness (or .015 inches). That's pretty darn thin. Just to compare, LINE-X and Rhino will apply about 8 gallons solvent free.
Durability wise, Raptor (which is made in the UK) unfortunately does not publish technical specs. The only thing we know is that according to their site, it's "2K paint". However, assuming it's like all the rest of the solvent based store bought bedliner products, it's honestly not as durable as the professional products.
Again, I'm not trying to start any thing here, if one (or two) gallons of Raptor works for you, then that's all that matters.
DIY bedline
Just did my 09 SCAB. I took my time and scratched is all up as per instructions. even bought a rougher scouring pad to make sure. And you need gloves, tray to hold the stuff so you can use the roller and Xylene. All in, probably $120.
It took a long time to do, 6 hours, start to finish. And i did it in my driveway and the tree crap kept falling in the bed so i was picking out seeds all day. Once i was finished i backed it into my garage to cure.
Not sure i would do it again. Even for the $500 savings over a professional job.
I have personally done two Herculiners. And a friend of mine has done one. The first was in my 2000 Tacoma. It was a couple years later when I did it. I didn't do very good prep work, and did two coats over a couple weeks. (Do to impatience and work schedule) It held up fine for many years. My buddy who did his 2000 S-10 beat the absolute crap out of his bed in the past couple years with many truck loads of wood and it's held up fine.
This time around on my 2010 SCREW I took a lot of time in the prep work. I used 80 grit sandpaper and made sure I got every part of the bed and sides completely scuffed. 80 girt didn't have to press as hard to scuff as opposed to the scuff pad they supply. I probably sent 6 hours or so doing the bed (over a weeks time). I then taped off the truck and put on 2+ coats to the entire bed with the Gallon. Wanted to spray but the undercoating gun i bought wouldn't blow anything, so I rolled it on.
Since then i've had 6 loads of dirt and a couple loads of mulch. It's a little dirty but holding up great.
Really what is your bed for? Put dirt, rocks, wood, metal, deer etc.. It's gonna get beat up. Who cares if it fades in color or if it's 1/8 or 1/4 or 1/16 inch thick.
With the herculiner if you happen to tear it up you can get a quart and repair for $20-$30. Line-X you gonna spend $450-$550 and they should repair it if torn (depending on the local owner of shop, will the be there in 5-6 years when you need this repaired). Rhino i've talked to a couple shops, Do not cover tears and such, so your out the $400+ they charge for it.
If you take you time in the prep work you won't be disappointed.
I've used this 3m stuff and it's held up pretty well even after bending the tailgate.
http://products3.3m.com/catalog/us/e...er/output_hTml
In the end, if you DIY, you'll probably have to plan on doing scratch 'n' dent maintenance on it.
It use to be, IMO, until Dupli-Color came out with Bed Armor. Bed Armor is an awesome product and it comes with UV protection and made with Kevlar.
I have done herculiner on my last truck and it sucked. Granted I do think TIDOFX4 did a great job. And he's right, if you prep it well enough I think it will last. I didn't prep very well. Also I had an 8 ft bed and even two gallons wasn't enough to give it a true thickness to withstand stuff.
I got my 8ft bed done at ziebart for $350 (they were running a special last year). It holds up great and has a lifetime warranty. By the time you do all the prepping, buying materials, etc for maybe $100 more (when they're doing a special of course) you could get a lifetime guranteed product.
Then you don't have to ever worry if it flakes or not prepped right because they'll fix it, whereas diy has a chance you're going to have to do it again anyways. just my .02
I thought I would throw in some interesting information regarding DuPont Kevlar.
LINE-X and DuPont spent over two years developing the LINE-X Xtra product which contains Kevlar. LINE-X is the only DuPont authorized user of Kevlar for truck bedliners.
Here's what I've learned: You can buy some Kevlar and dump it in anything and you probably will think it's an improvement. In reality, the Kevlar could have the opposite effect. There's much more "science" to it than you think. Such as, how the Kevlar fibers line up and do the fibers interfere with the crosslinking of the other components.
Chances are, Duplicolor and other brands that contain Kevlar did NOT spend the time and money researching the effects of Kevlar. They probably didn't need to. All they want to do is sell you their product and just by putting the Kevlar label on the can might be enough for you to choose their product.
Just to be fair, maybe Kevlar does enhance Duplicolor, but I bet it's more of a marketing effort than anything else.
A new Choise in bed liners... Dual Liner
This is a really affordable way to get what you want, your stuff to stay in place and looks great too. Do yourself a favor and check out the Dual Liner, www.dualliner.com it really is the best of both worlds. You get the most protection and the best price, we have a couple of deals going on right now that we could blow away the competition with. Oh yeah, I forgot the best part you can check it out and if you don't like it you can ship it back. We are the new guys in the bed liner business and we have been creating quite a buzz. What is happening is we sell one to Billy Bob and then Joe Bob and Jim Bob are getting one too. I know that you would be extremely happy with our product so at least check us out. Let us know that you saw us on F150online.com and we take real good care of you. My email is todd@dualliner.com if you have any questions or you can call us at 1-800-992-1949. See why we are the real truck bed protection system!
I would hope you get the same service even if they were not part of this forum.
I just thought I'd give a little tid bit of info I have about roll on liners. I've never installed one but I bought an 05 that has a DIY liner rolled in on it. The original owner said he did it when it was brand new so the surface was already clean. He wire wheeled the surface, cleaned and rolled it on, that was 5 years ago. Today its sun bleached almost gray/white. It still is stuck on there pretty good but is kind of thin in some places. I called Linex to see about getting a liner sprayed in and they told me my situation was the worst. Since I have a DIY roll in liner they said they'd have to scrape/sand the old liner out then spray in the new one which equals very $$$$ about close to 1k. He did say they Linex offers a process to spray over the top of my existing liner but comes with no warranty and runs the same amount as getting a liner put in a clean bed. So I guess the reason I'm posting this is as a word of caution, you only get one shot with the DIY liners so make sure thats what you want before you do it. Also make sure you get something with UV protection so it doesn't look like crap later on. Since mine is stuck on so good though i might try the Linex and just hope I don't have to worry about needing a warranty.
