I'll give you some info and you can decide what's right for you. I'll compare/contrast with LINE-X.
Scorpian (Speedliner, and Superliner) are solvent based products sort of like paint (LINE-X does not contain solvents). The Scorpian dealer first must apply an adhesion promoter to the bed because the bedliner product does not have good adhesion (LINE-X does not require an adhesion promoter in truck beds). Then the Scorpian dealer paints it on with a brush, rolls it on with a roller, or uses a hopper gun (LINE-X used a heat/high pressure application). Like paint, Scorpian bedliner takes an hour or so to dry and 72 hours to cure (LINE-X dries in 4 seconds and cures within 24 hours). Scorpian's warranty is only with the dealer that applies it (LINE-X's warranty is a lifetime warranty that's valid nationwide).
I don't know if you have ever heard of Al's Liner, but Al's Liner is retail packaged Scorpian. I have info from Al's including several samples. I can tell you that the samples are NOT very strong.
Scorpian:
LINE-X Xtra:
Al's Liner samples. The red one has red glitter in it, the kind you used in Kindergartan.
