Few things to consider:
1) Avoid duplicrap, that's just what it is.
2) I am a Superliner dealer here in central MS and I use a 25 dollar gravity feed hopper gun from Harbor Freight. It works great
3) Your compressor needs to be able to run a good bit of pressure at full throttle of that air gun or it will use a lot more material faster. Superliner goes on the best with my compressor putting out 100 psi at full throttle. If yours isn't big enough to put out at least 80, I'd roll it on.
4) If you spray make sure you mask off EVERYTHING around that you don't want overspray on.
Hope this helps
