F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Bedliners, Caps, Tops & Lids
Thread Tools Display Modes
Old 01-14-2009, 07:19 PM
Vehicle: 2006 Ford F-150
Question Who has an Access Roll-UP????
Any Acess Roll-Up owners out there? I've got some installation / operation questions I'd like to seek help with. Any support is appreciated.
BigSur
2006 Lariat
Newport News, VA
Old 01-14-2009, 11:08 PM
Vehicle: 2005 Ford F-150
I have one as you have already noticed, however I cannot really help you much because the store I bought it from installed it for me.
Mods: 2005 Lariat 2wd
6" Fabtech
Fabtech Steering Stabilizers
Line-X
35x12.50 18 Toyo M/t's
18" Rockstars
Access Roll up cover
K&N Drop in air filter
35% tint on fronts
5% Sun strip
Soon to come:
Patriot decal Ovals
Gas
Old 01-14-2009, 11:34 PM
Vehicle: 2007 FORD F150
all the tonneau's go on in the same fashion, what you have problems with?
Old 01-15-2009, 12:38 PM
I'm really just curious how tight you keep the vinyl. I had an accessory store install mine but quickly realized that it was basically "slammed" in with no quality. I ended up correcting most of the issues and everything is good.
However, I've been trying to keep the vinyl taut, but not too tight becuase I don't want to overstretch the vinyl. The back snaps in securely but I don't have to apply much pressure to snap it down. The way I have it now, there is a minimal amount of play in the material, so it does wave around a little while driving. My biggest issue is that it collects a minimal amount of water when it rains (turned to ice the other night and stained the vinyl!!!), and I'm not sure if that is typical.
Does youse guys covers collect water when it rains?....or do you have it tight enough to avoid that? How much pressure are you applying when you snap the back down? The instructions say 20-30 LBS of pressure. I have a hard time gauging that. Thanks in advance for the help guys. Always appreciated.
BigSur
2006 Lariat
Newport News, VA
Old 01-16-2009, 10:45 AM
Vehicle: 2000 Ford F-150
Go ahead and tighten it a little. There will be a little sag and water build-up like that just the nature of vinyl covers. You don't want to tighten it to much during the winter cause come summer you will be tightening it alot to accomodate the stretch of the vinyl in the heat.
Old 01-16-2009, 01:04 PM
Quote:
Agreed, it got down to about 15 degrees here last night. I could tell that the vinyl got tighter. I basically just ensure the back snaps down with "some" pressure but not much. When it was installed, the back pretty much fell into place with no effort. I tightened each side about 1/4 turn.
BigSur
2006 Lariat
Newport News, VA
Old 01-18-2009, 03:18 PM
Vehicle: 2006 Ford F150 fx4
I have had 2 of them one on my 03 and one on my 06. In the winter it does get a little loose. I have water collect in between the bars but not much. As far as staining goes mine will stain at first but after a good detail the staining disappears.
Old 01-18-2009, 08:43 PM
Vehicle: 2005 Ford F150
Count me in as having one but the store i got it from installed it. Ive had no sagging issues though and havent had to tighten it through any seasons. No ice or water buildup. The snow built up on it one day but after i brushed it off it went back to being normal/tight.
2005 XLT Scab
Upgrades: Flowmaster 40, Magnaflow High Flows, PHP Gryphon, K&N Air Filter, Infinity Kappa Series Speakers, Access Roll Up Bed Cover, Stainless bed rails
Coming Soon: AS 2.5' Leveling Kit
Old 01-19-2009, 05:41 PM
Vehicle: 1998 Ford F150
I installed my access Roll cover seven (?) years ago. I have the velcro. If you had a store install it, go back and ask for the instruction or go some where and ask for a copy of the install instructions; or see if the instructions are on the internet. There should be room for adjustments. Snug, but not too tight would be better.
I have had little or no staining, but the truck is parked inside. But, it gets wet a lot here and no problems.
Sound like you are on the right track with the quarter turn tightening.
TT
Old 01-20-2009, 11:24 AM
I just tightened mine after reading this post. Mine was 3 full turns out from being tight. I read the instruction book and it says it needs to have 30lbs of force to close and to use your household scale to judge it. I will check mine again this summer.
Old 01-21-2009, 04:58 PM
Thanks for all of the replies guys. I noticed the instructions saying 20 to 30 lbs of pressure when closing but had a hard time gauging that. Didn't think of using a standard weight scale; might have to try that. I still think mine may be a little loose becuase it does hold some water in the rain. Other than that, seems okay.
Does anyone on here have a short bed? I noticed that my support bars on the cover aren't centered. I have 2 bars. One is about 1 to 2/3 down the bed from the cab. The other is only 1 foot away from the tailgate. Wondering if this is standard for Roll-Ups made for short beds. If not, that may also be causing the problem.
BigSur
2006 Lariat
Newport News, VA
Old 01-24-2009, 08:31 PM
I have three. One a foot away from tailgate, one in middle, and one 18 inches from the window. I'd bet you are missing one.
I do have a short bed
TT
Old 01-25-2009, 03:57 PM
TT
Do you have a short bed (5.5 ft.)??
BigSur
2006 Lariat
Newport News, VA
Old 01-25-2009, 09:09 PM
I have the 5.5 bed and mine is the same way with 3 supports. Mine actually sags worse in summer than winter when the sun bakes it, things seem to loosen up. I keep mine probably tighter than you are supposed to because I don't like it bucking, so far I have had no issues with it.
How are you guys getting rid of the water stains ?
Old 01-26-2009, 05:40 PM
I'm not sure what is going on. I just got off the phone with the manufacturer and they assured me that the covers for the 5.5 ft bed have "2" support bars, not including the head rail of course. Oh well.
As far as stains, try a good wash and some Meg's Hyperdressing. Works for me.
BigSur
2006 Lariat
Newport News, VA
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
