Well guys, I think Im gonna go with a bedrug instead of linex. Got a few questions for ya though, what do those of you with the bed tie downs use instead of them now? Im pretty sure the bed rug covers them up, just curious how you strap stuff in now.
Remove the tie downs and re-install just the screws before you put the bedrug in. That way, when you put the bedrug in, you can find where the holes should go (by feeling for the screws). Cut a small hole in the bedrug, remove the screw, re-install the tiedown and you're done!
well, thanks guys. but there seems to be one problem, damn tie down bolts are threaded out. stealership messed up when they put in the liner. can i install the bedrug with the tie downs still in without removal?
If you can't get them out, you could put some heavy duty double sided tape (waterproof) around each tie down. That way, when you cut the slit for the tie downs, you could reach in & pull the tape off the face & then press it into the liner.
