Short answer NO. Long answer..... NO. Throw the Armor all away. It's sylicone based. Once you use it it will turn white and will have to use it over & over again. Bad thing is, you can NEVER clean it off if you had to paint over it or anything as nothing will stick to it once it's applied. Only use it on thrue rubber products if you must.
__________________ 2001 F150 4x4 slowly becoming the Harley Davidson edition
Another reason not to use armor all is that it will make the liner slicker than hell, especially if it gets wet.
The only thing I use armor all for is practical jokes, like applying it to someones steering wheel or snowmachine seat.
Any silicone based product will cause your bed to be a "slip and slide". In addition, if any repairs need to be made to the Line-X bedliner, will cause the Line-X shop much grief. I would recommend a product called "Just Once". It does a great job in bringing back a "like new" finish to your bedliner. I recommend to our customers to wash your bedliner with a stiff brush and Simple Green. Then rinse the bed throughly with water and allow to air dry completely. After the bed is dry, spray the bed with Just Once or other equavalent products (Armor All Low Gloss, Meguire's) any UV protectant that DOES NOT CONTAIN SILICONES! Once dried, your bed will look like new. I recommend this process every 3-4 months.
Yea, what he said, Just Once (justonce.com) or 303 Aerospace. If you have LINE-X Xtra, just wash it with automotive soap and water. You won't need anything else.
