F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Bedliners, Caps, Tops & Lids
Thread Tools Display Modes
Old 08-30-2008, 09:00 PM
Vehicle: 2000 Ford F-150
Plastic bed rail covers and spray on bed liner?
I have a 2000 F-150 that I use for camping. I would like to get the bed lined (line-x or rhino) and I am concerned about the plastic bed rail covers.
Can I take them off? Do I need to? I would like the liner all the way around the top of the rails. The bed liner place said they were an integral part of the bed construction and that if I took them off the bed would be weaker.
I have a hard time believing that a ****ty plastic rail cap would have that much importance, but Ford has surprised me before.
The whole deal is simple, I have a camper shell which I would like to bolt to the bed permanatly. I want the whole bed lined so it wont rust. I will seal the holes after I drill. With all the little gaps in between the body parts i want the back to be as water tight as i can make it because wet sleeping bags suck.
So anyone with any ideas or experiance please let me know.
Old 08-31-2008, 03:51 PM
Vehicle: 2004 Ford F-150
Send a message via AIM to DarrenWS6 Send a message via Yahoo to DarrenWS6
Go with Line-X, and they will do all of the necessary measures when you take the truck in. Such as removing the caps, bed bolts, bed hooks...
2004 Ford F-150 XLT Supercab 5.4L 4x4
Appearance: Painted Headlamps/Fog lamps, 20% Tint
Performance: PHP Gryphon 87 Perf, 2.5" True Duals X piped, Rear Cats Deleted, Magnaflow 11" Bodies, Magnaflow 4x18 Rolled Tips.
Suspension: Bilstein 5100 Leveling Struts & Rear Shocks, 20x9 XD Monsters, 33x12.5 Toyo M/Ts
Videos: Start Up, Revs, Driving. Fly-By Sounds Burn Out Video Interior Sound/Drone Tunnel Carwash Rev
Old 09-01-2008, 12:23 AM
You'll need to keep those plastic rails on. If you take them off, you will see a bunch of rectangular holes all the way down the rails.
The bedliner dealer will not remove them, they will mask them off prior to appying the bedliner.
Old 09-01-2008, 06:30 AM
Thanks for the info i will remove them for the lining then reinstall. Anyone know of a good replacement for them i.e. diamond plate
Old 09-01-2008, 01:33 PM
Vehicle: 2005 Ford F-250
if you were to put diamond plate bed caps could you line ex over them since their metal?
Old 09-02-2008, 10:22 AM
The aftermarket aluminum diamond plate bed rails attach to the factory plastic caps with 3M double stick tape (and one screw on each side). A good brand is Dee Zee.
It's really not a very good idea to apply a bedliner product to aluminum rail caps. Aluminum has a unique property when exposed to water called cathodic migration which can lift the bedliner material (or primer) from the aluminum if there is an edge (edge of bedliner and aluminum) exposed to water.
Old 09-02-2008, 09:50 PM
I have a Pace Edwards retractable bed cover whose guide rails are powder coated aluminum and the PC has worn away to almost nothing. I was going to have them shot with Line-X to match the bed. No good??
Old 09-03-2008, 10:37 AM
Pace Edwards covers have a three year warranty, is it still in warranty?
Old 09-03-2008, 11:31 AM
No, it's about 6 years old.
Old 09-03-2008, 11:46 AM
Vehicle: 2004 ford f150
Send a message via AIM to Jditta
CAn the plastic bed caps on the 04 up f150's just be line-x'd along with the bed?
Justin
Old 09-03-2008, 12:00 PM
I don't think a bedliner product could be applied to the Pace Edwards rails and look nice and still allow the cover to function properly. I think you're better off either painting it or having it re-powdercoated.
Typically, when your dealing with fairly flimsy plastic, it's best to apply the bedliner all away around to totally encapsulate the plastic, as we do with say....Bushwacker flares. The plastic rail caps can't be totally encapsulated (or else they would not fit back onto the truck) so, I would discourage spraying the caps.
Old 09-03-2008, 12:05 PM
They can't be sprayed while still being on the truck?
Justin
Old 09-03-2008, 12:54 PM
I don't recommend it and I would not do it at my shop.
But, that doesn't mean you won't find someone who would do it.
Old 09-03-2008, 01:12 PM
Just curious as to why you wouldn't do it?
Justin
Old 09-04-2008, 11:14 AM
There are too many negatives to the application:
1. The plastic is flimsy and thus is not a good substrate.
2. You can't encapsulate the plastic (which you would want to do since it's flimsy).
3. There is too much water exposed LINE-X/plastic edges (on this flimsy plastic).
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
