F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Bedliners, Caps, Tops & Lids
Thread Tools Display Modes
Old 11-22-2006, 01:58 AM
Vehicle: 2006 Ford F250 PSD
Big Mistake, can you remove a spray in BL?
Ok, I made a mistake. Long story but to make it short.
Is it possible to remove a recently sprayed in bedliner to get a different one redone?
Rather than having the original "fixed or repaired" due to bad application I would rather have it removed, cut my losses and get a different one put in.
Please don't dog pile me on this, I am already kicking the crap out of myself for getting this one.
RollingRock, Keller Texas, 2006 F250 PSD King Ranch, Dark Copper.
Line-X with Xtra.
Old 11-22-2006, 10:35 AM
Go buy one of the dewalt braided wire wheels for your grinder and start grinding, some bedliners are softer than others so the amount of time it will take will depeond on the brand of liner. Be sure to wear gloves and safety glasses buecase those wires fly out the further you get into the job, it will probably take a couple days of grinding but you can get it off. Don't worry about damaging the bed as the wire wheel will only take the paint off, it won't go through the steel.
Good luck!
Also, when you get done, your hands will be partially numb for a week or so.
Old 11-22-2006, 11:12 AM
Vehicle: 1997 Ford F150
heat gun and a puddy knife then use that grider to remove the rest it will speed up the process or just add a drop in you have ssome thing to protect it now
97 F-150 4.6L 4x4
6in Fabtech suspension lift
superlift 3in add a leafs
2in PA body lift
35'' **** Cepek FC-II
16x8 Mickey Thompson Classic II
4.56 gears
drilled and sloted rotors with greenstuff pads
k&n cold air intake
Edge Programer
Custom headers
2 high flow cats Cherry bomb extreme mufflers true dual set up exit in front of rear wheels
Westin Nerf Bars
Westin One Piece Grille Guard
http://www.f150online.com/galleries/....cfm?gnum=8529
not bad for a Redneck Marine
Old 11-22-2006, 11:46 AM
Oh no, I don't recommend either of those methods.
We talked about a color match. You could pic the copper OR the beige trim color.
Old 11-23-2006, 10:03 AM
Go to a truck service box place, and find a take off bed that matches yours.
Old 11-27-2006, 08:13 AM
the heat gun and puddy knife will work to a small extent but not worth the effort, the grinder with the braided wire wheel is definitly your best bet, it will take off whatever was sprayed in there.
Old 11-27-2006, 11:40 AM
Goat Herder Extraordinaire
Vehicle: 1999 Ford F150
Quote:
Originally Posted by Duffman0286
... or just add a drop in, you have something to protect it now
I agree with that. Even a poorly applied spray-in will compensate for the drop-in negative points.
If I had two spray jobs, I'd be out the cost of one spray job.
If I had one (bad)spray job and one drop-in, I'd be out the cost of one drop-in.
And a big plus would be no grinder, no heat gun, no putty knife, no worries.
Old 11-27-2006, 07:36 PM
Freeze it! You will figure the rest out.
Old 11-27-2006, 09:05 PM
Vehicle: 2006 Ford F150
Quote:
Oh no !! Does this mean my spray in liner might flake off this winter? I hope it comes off in one piece then I can use it for a drop in.
Old 11-27-2006, 11:16 PM
If you wire wheel it, make sure to wear some sort of respritory mask. Even just a paper face cover will at least stop the big stuff from getting in your lungs.
Sorry dude
P.S. If it's a bad app, could you take it somewhere to have it done profesionally, and then backcharge the company that did the poor job? Not trying to tell you what to do.
Rhino Liner
Clear Coat
Modified Y pipe
Magnaflow SIDO
Troyer Tuned XCal2
LiquidMetal Wingman Wheels
Michelin LTX A/T2 285/55/20 tires
I reject your reality and substitute for my own.
Old 11-28-2006, 09:06 PM
We usually get them out by cutting them with a utility knife into about 2 inch wide strips and pulling them out with the help of a scraper...
Old 12-03-2006, 10:37 PM
Dang guys, I totally didn't mark this thread to remind me of replies..
Thanks for all the suggestions. I think I got it worked out with Truckgasim...why does that sound strange to say outloud?
Anyway, I will be removing this POS liner after Christmas and having my local Line-x do it right.
Personally, I think I could just peel this one right off.
Line-X with Xtra.
Old 12-05-2006, 08:33 PM
Put a cover over the bed and blast it with a stick of dynamite...
Just Kidding
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
