F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Bedliners, Caps, Tops & Lids
Thread Tools Display Modes
Old 10-02-2006, 03:12 AM
Vehicle: 2001 ford f150 4.6 4x4
about sprayin liners
i want to know if you get a spray in bed liner how do you take the bed off if you need to
Old 10-02-2006, 11:51 AM
Tell the bedliner dealer to remove the bolts prior to spraying the bedliner and the reinstall them after the bedliner is applied. No big deal, we do that with 99% of our customers.
Old 10-03-2006, 04:09 PM
if it was you truck would you take the bolts out
Old 10-03-2006, 06:06 PM
Yes I would.
Tailgate access panel.
Old 10-03-2006, 07:09 PM
Vehicle: 2006 Ford F-150
Tailgate bolts yes, bed bolts no. If my bed ever needs to come off, its because my truck got hosed in a collision. Most likely the bed is getting replaced. It looks much better with the bed hold down bolts sprayed. Plus its one less thing to beat up / rust.
Old 10-03-2006, 08:59 PM
A collision is not the only reason why the bed may need to come off.
Not a Ford, but the bed looks a little nicer when the hardware is removed first.
Old 10-04-2006, 10:04 AM
Vehicle: 2005 Ford F150
Send a message via Yahoo to LoveMy RST
I agree---I think the bed looks cleaner with the hardware removed before the liner is sprayed.
Old 10-19-2006, 12:11 PM
Vehicle: 2006 ford F150
You can remove them after and spraypaint the washerws adn tops of the bolts if you want the black look but still want the functionality of being able to remove them.
2006 Ford F150 Lariat 4x4. Medium Wedgewood, Tan leather trimmed Captains, 20" Wheels, 6.5' Bed, 3.55 LS, Tow package, Sirius Radio.
MODS: Performance Accessories 3" Body Lift, AF-1 Intake, Vortex Spray-In liner, Rain Guards, All-Weather mats
Old 11-01-2006, 12:25 PM
Vehicle: 1997 Ford F150
Send a message via Yahoo to MrWSM1
What is the difference between Line-X and Toff spray on bed liners? Also, I have pretty significant dents in my wheel wells where a pallet was shoved into it. Will the bedliner spray cover these up or should I hammer them out a little. Thanks!
Old 11-01-2006, 12:29 PM
I would remove b4 the spray. What if you wanted a body lift installed down the road
-2005 F150 FX4 Loaded
-6" Fabtech Suspension Lift
-2.5" Daystar Level Kit
-Fabtech Dual Steering Stabilizer Kit
-36x15.50 Claws
-20x10 Moto Metal 951
-True Dual Flowmaster 40 Series Exhaust
-Back 2 Cats Cut Off
-Edge Level 3
-Tinted Windows
-Entire Windshield Tinted 35%
-SuperWhite Head and Fog Lights
-Vent Shades
Old 11-01-2006, 03:01 PM
Quote:
Toff: Operates mostly in Texas, is a 100% polyurethane liner exactly like Rhino. Toff has downsized in the DFW area and myself and two other LINE-X dealers hired Toff's outside sales rep. Tear strength is 200 pli, temp tolerance is 212 degrees. (Actually, I doubt the 212 degrees, it's probably more like 175 degrees.), softer liner at Shore A 85. Toff uses a cold/low pressure application system, it gels in about 30 to 45 seconds, dries in about 45 minutes, cures in 24 hours. Warranty is only with the dealer that sprays it.
LINE-X: Polyurethane/polyurea blend, tear strength 304 pli, temp tolerance 250 degrees, uses a heat/high pressure application system (for better adhesion and a more uniform looking final texture), harder at Shore D 45, dries in 4 seconds (follows the bed's contours much better), cures in 24 hours. Warranty is lifetime valid nationwide.
Hard to say if the bedliner will cover those dings, need to lay an eyeball on it to see.
Old 11-01-2006, 07:21 PM
TruckGasm,
thanks for the info. Do you operate in the DFW area?
Old 11-01-2006, 11:23 PM
Yes: www.linexfortworthtexas.com
Let me know if you have any questions about any brand bedliner. If I have any information, I'll be glad to share it with you.
Old 11-02-2006, 11:53 AM
Vehicle: 2000 Ford F-150
Truckgasm,
Do you (or any other liner installers here) normally spray liner on the tops of the side rails and tailgate as a replacement for the factory plastic protectors? Is that something that is/isn't recommended? And how much extra do you charge (if any) to do it?
Gig 'Em Aggies!
The only good longhorn is the one that ends up on my plate.
Old 11-02-2006, 12:45 PM
We do not apply LINE-X to the plastic rail caps or tailgate cap. Plastics can be sprayed but plastics are a little tricky. You're better off buying aftermarket aluminum or steel rail caps and then, if you wish, have those LINE-X'd.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
