I just put a Penda liner into my 03 and was amazed (read pissed off) to find the front bed tie downs to be covered by removable rubber plugs in the bed liner vs being set up so the tie downs bolt up thru the bed liner like they do in the back.
The Penda liner in my 98 F150 was set up with these bolted thru. What a stupid design change.
Don't buy a Penda liner....
07 F150 Lariat Supercab, 6.5' 4x4, 5.4, 3.73LS, 7.5' Fisher SD Plow, Gryphon Custom Tuned!!
08 Explorer Limted 4x4, 4.6
93 SVT Cobra #2205, Featured in 5.0 Mustang & Super Ford, SVTOA Calendar (Dec - 2008) and Now Garage Art
91 Harley Davidson Sportster - Mild Custom
IMA on both issues, I have the Penda also and had to "add additional hold down power" "screws" in the center of the bed at the tailgate because it would always bow upward in the heat, so much so that you could stick your hand under the liner.
Well no problems with ours. It is under the rail & seems to fit well. It does have the removeable plugs up front covering the tie downs, but it didn't concern me much. Only time will tell how it'll last. I do like the skid resistant texture of the liner.
yeah, mine says skid resistant too. that means if you are sitting still, engine off, and no wind- most objects will not slide around. mine is now slicker than a hog covered in snot since i spilled about 4 qts of tranny fluid in it
