Mount tiedowns on top of bedrug
Just be careful when you cut the bedrug for the screws to pass through. Once the tip of your knife breaks through, it's really easy for the blade to pop on through and cut quite a bit more of a slit than you intended.
As I recall, I removed the tiedown, then pressed the bedrug against the wall of the bed over the spot where the tiedown had been, and it left an impression in the back of the bedrug where the screws are. Then you can slit the bedrug from the backside. Like I said though, be careful not to overcut.
'01 XLT SCab Flareside
5.4L 4x2 Sport
