Home Discussion Forums Photo Gallery Vendor Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Ford & Industry News Vin Decoder Advertise with us
Go Back   F150online Forums > Special Interest > Articles & How-To's
Sign in using an external account
Register Forgot Password?
Look for a USED Ford F150
Carsdirect.com
Thread Tools Search this Thread Display Modes
Old 12-16-2011, 01:12 PM
2007 Ford F-150
Vehicle: 2007 Ford F150
Torque Wrenches and Extensions.
I've seen questions come up about the use of torque wrenches with drive extensions and offset crows feet and beam extensions and effects of same and so I thought this might help others.
Here's a good read on Torque Wrenches:
http://www.algeo.com/~joe/KIAT/kiat_3.htm
And this one is worth adding to Favorites for it's plug in tables. Sometimes an extension might come in handy as well as knowing how it changes effective torque at a setting / reading.
http://www.freeinfostuff.com/TorqueE...eExtension.htm
And as to socket extensions .... see page 5 of this document.
http://buy1.snapon.com/products/torq...NET%20SITE.pdf
Also, I have this saved from a post I made some dozen years ago. It explains the use of drive extensions and a torque wrench very well I think.
Quote:
Will using socket extensions change torque wrench settings or applied torque?
No.
This has been argued for years and a drive extension will not change the torque value. It does not matter if the extension flexes (winds up) as you would simply pull the wrench farther around.
It is a simple law of physics, whatever force you input into one end of that extension is what is going to be exerted on the other end ... period. If you were getting less energy out of it than you put into it where on earth does that energy go then? If the extension twists then the wrench would simply require that much more movement as it is moving. When the torque setting is reached and movement is stopped then at that point the input force and the resistance is equal and that is what it will read.
Now if you allow the extension to lean over from the center of the fastener so that the wrench turning center is no longer centered over the fastener then you would get an erroneous reading because of the leverage factor, but this is something else entirely. For this same reason a crows foot extension must be compensated for and some wrenches include a chart for doing this but again this is for leverage because the wrench is not centered over the fastener.
Imagine using a rubber band versus a wire with two hooks to pull a 10 pound weight across your table. Both will pull it, both take the exact same "Force", but the wire doesn't stretch, the ryubber band will stretch as it stores "Energy". Once moved though, that "Energy" is still there in the rubber band, and the exact same "Force" is required to move the weight. You just had to move your hand further as you moved it, but it wasn't any harder to pull. The extra travel of your hand required you to expend more "Energy" but that "Energy" is still there stored in the rubber band after the pull.
An impact wrench uses "Kinetic" energy from "hits" to tighten a fastener, an extension will store part of that kinetic energy when it recieves it ... and then release that energy between each hit. Thus some of that "Energy" never reaches the fastener. That's how "Torque Sticks" work.
But you take that "Torque Stick" and use it as a socket extension with your old 1/2" drive beam or clicker torque wrench where you pull on a handle and apply "Force", it'll twist, but the torque applied at the wrench drive is the same as that applied to the socket, but you have "energy" stored in the "T-Stick" waiting to unwind as soon as you let it.
Energy and Force are two different things.
"Horse Power" is "Energy" ...
... and "Torque" is "Force".
Take a 1/2" nut and bolt, chuck bolt in vise, use beam TW and T-stick and tighten nut to 50 ft/lbs. Now, remove T-stick, check torque with same beam TW.
2007 F-150 FX4
SCabFS/5.4/AT/AMFMXM/H&AC/SCFP1865/UC2090/FMCB/TFAI/2&2Drop) ...
... and it's RED ...
and whatever you do, Have a Safe Trip!
Old 12-16-2011, 02:17 PM
Garage is empty, add now
Nice!!!
Truckless
Old 12-16-2011, 11:31 PM
2007 Ford F-150
Thank you Sir!
I discovered where the quoted part came from .... I wrote it in a reply on another thread in a motorcycle forum in 1999.
2007 F-150 FX4
Old 12-18-2011, 09:56 AM
2006 Ford F-150
My Garage
Vehicle: 2006 Ford F150
Good read Brought back memories of grade 10 physics
Craig
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
F150online - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Contact Details
