Removing rear door panel on 04-08 Scabs
Another member wanted pics and a write up for installing speakers in the rear doors, so here they are.
TOOLS LIST
small flat blade screwdriver (pocket style)
6mm socket or nutdriver
8mm socket or nutdriver
7/32" socket or nutdriver
1/4" or 3/8" drive ratchet and extensions (whatever size your sockets use)
Use a small flat screwdriver to pop out access panel to reveal screws behind handle.
Use an 8mm socket to remove these two screws
Grab upper trim panel and yank it off, it is held on with clips
now remove this screw it uses a 6mm socket
remove front trim panel and remove this screw, it also uses a 6mm socket
on the bottom of the door panel is more screws, 1 on scabs and regcabs, 2 on screws, they also use a 6mm socket
use a flat screwdriver to pry up switchpanel
remove this bolt under switchpanel it uses an 8mm socket
now lift and remove door panel and use a 7/32" socket to remove the four screws holding the speaker in.
TOOLS LIST
