How to change out front brake pads 04-08 F150
Old 01-25-2010, 08:26 PM
87fiveoh254's Avatar
I'm not sure. It should be pretty close, but the 4x4 set up could be different.
  #32
Old 04-18-2010, 11:32 AM
wreedKR's Avatar
I noticed the slide pins have notches on the sides of them, is there a certain way these are to be reinstalled?
Also is there a torque spec for the slide pin bolt?
  #33
Old 04-18-2010, 08:40 PM
wreedKR's Avatar
Bump
  #34
Old 04-18-2010, 10:42 PM
greencrew's Avatar
Bookmark.
  #35
Old 04-19-2010, 09:37 AM
wreedKR's Avatar
  #36
Old 04-20-2010, 02:24 AM
Cadillo's Avatar
The notches are to index the rubber boots. When you remove them and see how they are oriented, it will make more sense.
47 ft lbs. front, 22 ft lbs rear, per Chilton Manual. Worked OK on my '06 2WD.
  #37
Old 04-20-2010, 07:42 AM
wreedKR's Avatar
my boots did not have index notches. I put everything back togather the slide pins are in the same spot, but the notches are not and everything seems to be fine.
any ideas.
  #38
Old 05-17-2010, 02:43 PM
wreedKR's Avatar
Should i have put lock tite on the slide pin bolts?
  #39
Old 05-17-2010, 02:44 PM
Some do, I never have and never had a problem.
Old 05-17-2010, 02:45 PM
wreedKR's Avatar
very good thanks bluejay
  #41
Old 05-17-2010, 07:08 PM
wreedKR's Avatar
OK I dont know if this has something to do with the brake pad change but now when I come to a stop I feel a slight shudder/vibration. I dunno if this is the driveline or something related to the brake pad change.
  #42
Old 08-31-2014, 08:41 AM
mstarkfarmer's Avatar
I would highly recommend using loctite on the bolts which hold the caliper to the mount. I had one come loose even after torquing them to specs. Wired it up to get home. Loctite saves a lot of headaches and frustration.
  #43
Old 09-10-2016, 06:31 PM
safetyman6977's Avatar
F-150 Front Btakes
Thanks for posting this. I am not a mechanic, but this was easy as pie. Thanks much! Michael
Quick Reply: How to change out front brake pads 04-08 F150
